Valve covers leaking like crazy
72 cutlass 455 drivers side rear bottom corner bolt closest to the windshield looks like where the leak is coming from. Hard to really tell.
replaced with new edelbrock chrome valve cover and using rubber gasket. Have removed and replaced gasket 3 times & still no luck.
any ideas?
do I need different valve covers?
Edelbrock chrome valve covers known for leaking?
should I try cork?
leakin bad, any need help would gladly be appreciated.
would anything else in this area leak oil?
leaking down on the headers and smoking like crazy when I drive.
thanks!
any ideas?
should I try cork?
thanks!
Buy the good valve gaskets from Bernard Mondello Racing Enterprises. (not Mondello Performance of Paso Robles) Also make sure your valve covers are flat.
If you find another source for these gaskets let me know.
See this post: Best valve cover gaskets?
I'm on the website but no items listed?
Any ideas?
Thanks.
These are the best out there, extra thick and steel core and no need to apply adhesive. Priced great
Speedmaster® Valve Cover Gasket PCE353.1023 | Buy Direct with Fast Shipping (speedmaster79.com)
If however you take your valve covers off with any frequency the better gaskets will make it so much easier. The main advantages I see is that you don't have to worry about over torquing the gasket and they should last a long long time.
@JAXX455 Bernard is old school - you have to call him.
Thanks for the info and recommendation, I'll report back once I receive these gaskets and get em installed. Hopefully it solves my oil leak issue.
Thanks again!
NTXOlds
July 10th, 2021 03:19 PM
williamwallace11
April 5th, 2021 06:42 AM
