water valve on intake
Old December 15th, 2010, 03:32 PM
1973olds98's Avatar
Whats the wire that plug into the water valve for? And the vaccuum ?line..?/
1973olds98 is offline
Old December 15th, 2010, 03:39 PM
TripDeuces's Avatar
The vacuum line controls the opening of the valve, it's attached to the heater controls using vacuum to operate it. It's a heater control valve btw. As far as the wire I have no clue. Never seen a wire on a heater control valve. Unless it's attached to some kind of temperature sensor.
TripDeuces is offline
Old December 15th, 2010, 04:39 PM
The '73's have a temp. sensor on the water valve that turns off the "Low" speed on the fan (which is otherwise always on) through the "Low Speed Relay" when the engine is below something like 40°F.
It's completely unrelated to the action of the valve, which turns off the hot water when you select "High A/C."
It can be dispensed with with no noticeable difference in operation (just short the wire to ground for "constant-on" low speed). I don't even think you can get the valve with the sensor anymore.
MDchanic is online now
jensenracing77
March 19th, 2014 04:08 PM
svnt442
July 17th, 2011 04:43 PM
oldspackrat
April 20th, 2011 07:08 PM
rhett838
August 25th, 2010 07:01 PM
bullet1
September 3rd, 2009 05:43 AM
Quick Reply: water valve on intake
