Waterpump gasket
Old January 2nd, 2013, 09:18 AM
Olds Specialist LOL
JOHNNYOLDS442's Avatar
Waterpump gasket
Hey all,
Happy Newyear!
Unfortaunatly i was blessed with a leaky waterpump gasket.
Took the 442 for a cruise i figured what better way to ring in the Newyear right?
On the way home i smelt alittle antifreeze i said can't be me of course.
So i looked underneath the car at the next stop sign and sure enought we had a leaker.
Thanks god i was around the block from home.
So i parked it took a look upon taking it apart i noticed the bolts were not as tight as i would have made them, and that it was not leaking from the weep hole. There was a new pump put in recently an AC DELCO to boot.
So i'm going to try the gasket only first, the pump feels and looks brand new.
I took it all apart last night just have to pick up the $2.00 gasket today.
Anybody ever come across this or does it sound possible?
John
JOHNNYOLDS442 is offline
Old January 2nd, 2013, 09:34 AM
Originally Posted by JOHNNYOLDS442
Hey all,
Happy Newyear!
Took the 442 for a cruisei figured what better way to ring in the Newyear right?
So i looked underneath the car at the next stop sign and sure enought we had a leaker. Thanks god i was around the block from home.
So i parked it took a look pon taking it apart i noticed the bolts were not as tight as i would have made them. There was a new pump put in recently an AC DELCO to boot.
John
Is the leak coming from the gasket or from the weep hole on the underside of the pump casting nose? In any case, the gasket is easy to change. Be VERY VERY careful not to overtorque the 1/4" self tapping bolts that hold the pump to the front cover. These only thread into the sheet metal cover and the cover strips easily.
joe_padavano is offline
Old January 2nd, 2013, 09:41 AM
Olds Specialist LOL
no it was not leaking from the weep hole.
Ok thanks about the overtightening also!!!
I noticed when i did the plugs they were not overtightened either, you can tell who ever worked on it last did not tighten stuff enough.
Bobac455
December 4th, 2013 09:23 AM
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Waterpump gasket
