What the hell is wrong
Old March 8th, 2014, 12:20 PM
antweave's Avatar
I had a electronic ignition conversion kit by MSD in my 442 with stock 455. The distributor had fire and the coil was hot on both sides positive and negative side. So I decided to replaced the conversion kit to HEI. I bought a new locally from napa pit it in and still no spark at the plugs I tested the power source wire it is hot with the key on and the distributor has power to it but no damn power to the plugs I tested it with my test light and the distributor has power but no fire to the plugs. What the hell on the first try it fired once or twice then stopped firing what the hell is going on
antweave is offline
Old March 8th, 2014, 01:06 PM
JPMDaddy's Avatar
did you replace the resister wire power to the dizzy? If not, then you aren't getting 12 volts but more like 9volts - Not certain that this is problem, hopefully others will chime in
JPMDaddy is offline
Old March 8th, 2014, 07:19 PM
Those symptoms sound like a bad module. It's a new distributor but maybe the module isn't working properly?
Fun71 is offline
Old March 8th, 2014, 08:15 PM
Yes. How do you know that the new distributor is good?
And how on earth did you have a distributor fire? I've never even heard of such a thing.
MDchanic is offline
antweave
June 7th, 2014 09:12 PM
jeffreyalman
May 29th, 2010 06:37 AM
Uncle Hulka
January 31st, 2010 09:21 AM
Allan R
November 15th, 2009 07:53 AM
relic
February 23rd, 2008 04:43 AM
Quick Reply: What the hell is wrong
