what size or kind of carb?
hi i have a 72 455 out of a toronado im refreshing and i changed a few things just wondering what carb would work best budget is getting tight but i want something that will work good. heres what i got so far Ga stock heads small valves rv cam torker manifold its going in a cutlass with 3;42 gears flowtech headers no ac thanks 71 cutlass s
agreed on the torker. you need to be able to spin the motor up pretty good to make it work and the cam is going to want to work in the low rpm. put the word out and you may find someone that wants to swap for a performer.
The Q-jet will always have a 2mpg advantage over these other carbs, and will only be down on power to an 850 Holley-only because of sheer size.
BTW, part throttle response will be better with a Q-jet.
The only way to improve over a Q-jet is with fuel injection-ask Mark about the cost involved there.
Jim
My Torker worked just fine on a 8.1 smog motor running low 13s USE IT..........I would say a 750 vacum holley or maybe a 650DP I think a 750DP holley might be a tad much,I have never had good luck with Qjets mostly becauce there all wore to shyt by the time I got them and every machine or performance shop has Holley parts.......Jerr
72Cutlass
May 24th, 2021 07:24 AM
Oldsprepp
May 22nd, 2008 07:37 AM
BIGJERR
January 22nd, 2008 07:19 AM
