What is the thinnest composition head gasket?
I think the stock GM are .017. Mr. Gasket are .015? You said composition gasket, are you talking layered kind like MLS (multi layer steel)? Those are thicker with the thinnest being .027
Thanks for the info! I have a composition in my gasket set that is about .044, and I thought that was too thick. So I looked on summits web site and all they had was thick stuff or copper. If I can find a stock steel type gasket, that should be fine. Or a .015 mr. gasket should be even better. Where do they sell those? Anyone have a part #? thanks
I don't think you will find a composition gasket thinner than .028. I think the GM steel shim gaskets were .018. I believe the Cometic get down to .020-.024. This is what I have heard and could be all wrong.
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
