who here has stroked there 455
Old December 26th, 2010, 07:49 PM
fly1's Avatar
I saw a 4.5" stroke crankshaft from eagle for a BBO I have a bare block as well a a long block so I was thinking of stroking it to about 488cid. who here has done that and what kind of modifycations to the block had to be done and does it weaken the block or compromise the blocks intergrity
fly1 is offline
Old December 26th, 2010, 08:44 PM
cutlassefi's Avatar
Hit up Brian (507olds). He can tell you what you need to know.
cutlassefi is online now
Old December 28th, 2010, 03:56 PM
64Rocket's Avatar
Also "John " at Rocket Racing in Wisconsin
or
"Bill" at BTR Racing I believe in New York
Gene
64Rocket is offline
Old December 28th, 2010, 04:43 PM
cutlassefi's Avatar
I guess a better question would be what is your budget/goals?
Old December 28th, 2010, 04:44 PM
cutlassefi's Avatar
or
Gene
Make sure he actually has it in stock and get the price in writing.
Old December 28th, 2010, 09:17 PM
Rickman48's Avatar
My nephew did it - Rocket Racing assembled the short block and did the machine work! Has been working the bugs out this summer - making a pass next year!
Tires he had on his 461 don't come close to holding it - he's afraid he's gonna break the 10's and need a cage!!
Only remember minor grinding for rod clearance - shoudn't weaken anything!
Rickman48 is offline
Old December 29th, 2010, 02:46 AM
firefrost gold's Avatar
go to highperformanceolds.com its Bill Travato's site you can get the Book Max performance olds it will talk about a lot of the things you are looking for and info. 20 -25 bucks on ebay .
firefrost gold is offline
Old December 29th, 2010, 09:21 AM
507OLDS's Avatar
The 495" strokers are becoming popular with the street/strip BBO. 4.185" bore with a 4.500" stroke.Very minimal clearancing needs done at the bottom of the block,and it will not weaken it,but only remove what you need.You can stroke a stock 455 crank to the 4.500" stroke as well,and they will hold-up fine.There is still debate about which crank is stronger,the Eagle cast or a factory N-crank,but if you get an Eagle,have it checked to make sure it is straight,and the journals are right.Don't just assume it's ready to run because it's new. The journals on the 4.500" stroke cranks,Eagle or N-crank,will have 2.200" BBC rod journals,thus letting you install a BBC rod.They make a 7.100" BBC rod,which is great for this combination.Bill has a piston available for this,from CP. Eagle was also offereing a complete assembly,with Mahle pistons,in +0.030(488) and +0.060(495). If you have a stock bore block,just go +0.030,and leave more meat in the cylinder walls for better ring seal,and better cooling.Then you have more cylinder to go oversize in the future.We don't have a cylinder head that flows enough to justify going any larger than 4.185" anyway.Not even the best aftermarkets.
The 507 is somewhat of a dinosaur now.It was built before any of these parts or kits were available,and not too many people were making stroker or big-cube Olds engines.It consists of a 4.211" bore,with a 4.550" stroke.I needed a perfect N-crank to get that little extra.The rods are 6.800" Eagle BBC,which were the longest available at the time.The pistons are Ross +0.060 455 Pontiac(4.211" bore),and they have the same .990" wrist pin bore as the BBC rods.Everything is/was off-the-shelf parts,and the N-crank was offset ground.In hindsight,the bore should have been 4.191",which is a Pontiac size,making a 501,or a 4.181" bore,making a 500.It was a fun engine to do,and runs great,but there are better ways to do this now.
507OLDS is offline
Old December 29th, 2010, 01:18 PM
fly1's Avatar
It will be a street strip car but I have 2 blocks one is bare and the other is complete bumpy need the # 7 cylinder resleeved. So I am weighing out the options how I should go about the build the bare block will most likely be the block I use. As far as a budget this will most likely be a 4 to 5 yr project I don't spending money but don't like wasting money nor taking the engine back apart after its been assembled. But I'm giving myself a $6000 budget on the engine alone. I want to be able to spank some ls3.
fly1 is offline
Old December 29th, 2010, 04:14 PM
380 Racer's Avatar
IMHO I don't believe you can do it right for $6000.
380 Racer is offline
Old December 29th, 2010, 09:13 PM
Originally Posted by 380 racer
imho i don't believe you can do it right for $6000.
x2
Old December 30th, 2010, 04:36 AM
507OLDS's Avatar
I just finished in install last month of a 495" W30 "restoration" engine.It looks bone stock on the outside,but has the 495" rotating assembly.Bill at BTR built the engine.It started out as a good 70 455 core.
W30 replica intake
Q jet
Cast iron heads with stainless 2.072/1.710 valves with a little bowl blending, Solid bronze guides/ valve job/ 7/16 screw in studs
MLS head gaskets
CP Bullet pistons/7.100 H beam rods
4.185 x 4.500 stroke
Coated Clevite bearings
BTR multi hole timing chain set
ARP harware
Comp hydraulic roller 242/248/110
Harland Sharp rockers of course
OPP deep pan and pickup
Melling HV pump
ATI balancer
Steel flywheel
This engine made 442HP & 523FT-LBS with the stock WZ manifolds,and it made 482HP & 577FT-LBS with 1 7/8" headers. 93 octane pumpgas engine The cam is on the conservative side,since the car has AC,power brakes,etc.
That was $10k. No disappointments. No inflated dyno numbers.
507OLDS is offline
Old December 30th, 2010, 04:52 AM
fly1's Avatar
Did the $10000 include assembly too
fly1 is offline
Old December 30th, 2010, 04:57 AM
507OLDS's Avatar
All machine work,parts,assembly & the dyno time,but NOT the installation into the car itself.
507OLDS is offline
Old December 30th, 2010, 06:12 AM
Fly 1 were are you located ?
Old December 30th, 2010, 08:30 PM
fly1's Avatar
Im in San Antonio TX
fly1 is offline
Old December 31st, 2010, 04:44 AM
507OLDS's Avatar
Keith Steele is in Texas somewhere.He had Bill do his new engine as well.There are a few pictures of it in his book.
507OLDS is offline
Old December 31st, 2010, 07:46 AM
fly1's Avatar
How much u guys spending on machine work most of the assembling I plan on doing myself
fly1 is offline
Old December 31st, 2010, 07:59 AM
cutlassefi's Avatar
Bore and Hone with torque plate $225.00
Balance $175.00
Align hone $175.00
Deck $150.00
Press pistons $8.00 each, recon rods $15.00 each.
Add $125.00 to bore with my BHJ plate. My guy is in Jax Fl.
Old December 31st, 2010, 09:11 AM
fly1's Avatar
That's sounds like good prices roughly $1000 for the block machining. So if I assemble my engine I think $6000 should get me where I want. If the block and crank and cam bearings are good and balanced I van take it from there.
fly1 is offline
Old December 31st, 2010, 11:04 AM
cutlassefi's Avatar
Imo don't trust the balance job done by Eagle, have it checked.
Old December 31st, 2010, 11:21 AM
507OLDS's Avatar
What about heads,cam,valvetrain? All that stuff adds up.Yes,you can save a few dollars by assembling it yourself,but still don't think you'll do it for $6k if we compare apples to apples.
507OLDS is offline
Old December 31st, 2010, 01:13 PM
citcapp's Avatar
6K seems light to me for the completed deal. Intake, carb, headers, head work, ignition sytem, even if you buy edelbrocks heads you still need to do port work and their factory valve job is not the greatest. I'm thinking more like 8K from my research. Of course in Washington state all machining costs compared to other areas is 15 to 20% higher. Don't know why just is.
citcapp is offline
Old December 31st, 2010, 03:04 PM
fly1's Avatar
Ok I see where your coming from the $6000 is not including carb, headers, ignition or accessories or dyno testing. I'm figuring $6000 for long block with edelbrock heads ported and different valves and springs. everything else I either have or can or still debating how I should go. but this is a project that will most likely take a few years
fly1 is offline
Old December 31st, 2010, 03:17 PM
toro68's Avatar
Fly,
I PMed you a phone number of an Olds buddy of mine, so you can pick his brain.
toro68 is offline
Old December 31st, 2010, 09:02 PM
sx455raidercelticfan's Avatar
im stroking a 455 with eagle crank,rods and mahle pistons, i just had it checked and ballanced they ground it 10 on main and rods and it was brand new, shop around for your parts its cheaper than buying a kit!! i got the 4500 crank for like 450 shipped, 325 for the 7100 rods and 600 for the mahle pistons, it wont be done for 3-6 months and i figure its going 2 cost 9-12, im going with cnc ported edelbrock heads and full roller, all the little parts add up just the flywheel and damper was around 750 and that was with cheaper parts, a cheap oil pump was 350! it adds up FAST!! ill post pics as soon as the short block is assembled
sx455raidercelticfan is offline
Old January 1st, 2011, 09:39 AM
507OLDS's Avatar
Take your time & do what you can.Do a little,then regroup,then do a little more.Sounds like you will do that anyway.
507OLDS is offline
Old January 1st, 2011, 09:49 AM
citcapp's Avatar
Shopping around and taking time to collect parts is more then worth the effort. I spent the last 2 years collecting parts for my current 455 build that is now in the machine shop. Pistons, rods, Edelbrock heads, roller rockers, intake manifold, cam, etc, all bought through members on this site, on the Hamb Site and on ROP from builds not completed or when they changed their minds on the direction their builds. Saved 2K or better on new parts alone. Only thing bought so far new is the oil pan, pump, pickup, windage tray, timing chain, and ARP main stud and head stud kits. Still I will be around 5K on the build and its not a stroker.
citcapp is offline
Old January 1st, 2011, 11:40 AM
fly1's Avatar
I'm still not 100% sure if ill stroke it or not but I'm definitely leaning that way. I just like being able to use a tighter converter and a taller rear gear if it pulls a good low end torque number. With a overdrive I can cruise and mash out.
fly1 is offline
Old January 1st, 2011, 11:41 AM
fly1's Avatar
By the way happy new years to everybody
fly1 is offline
Old January 1st, 2011, 12:23 PM
  #31
panos's Avatar
I dont really think you need to stroke it you can get decent tq numbers with a well build 455,just for reference my 461 has 500+tq at around 3600rpm. Ofcourse more cubes is always good
panos is offline
Old January 5th, 2011, 12:40 PM
  #32
fly1's Avatar
I talked to some machine shops not sure i feel comfortable with them. Anybody know a good olds machine shop in tx. Or should I ship my block of to btr or dick miller
fly1 is offline
Old January 5th, 2011, 12:59 PM
  #33
cutlassefi's Avatar
Or you can ship it to my guy in Jax Fl., certainly closer than BTR. He has my BHJ/Olds Bor-Tru plate, a Torque plate and has done a half dozen or so Olds blocks just for me in the last couple years.
I highly recommend him.
Old January 5th, 2011, 02:02 PM
  #34
fly1's Avatar
What's your guys name and number
fly1 is offline
Old January 5th, 2011, 02:36 PM
  #35
cutlassefi's Avatar
Mark Hedrick of Horsepower by Hedrick Jax, Fl
904-771-2739
http://webcache.googleusercontent.co...edrick&ct=clnk
Tell him I sent you.
Mark Remmel
Old January 5th, 2011, 03:17 PM
  #36
dsa2207's Avatar
I have a 496 ci in the car in my avatar and it's a real tire blaster.
dsa2207 is offline
Old January 5th, 2011, 05:02 PM
  #37
what kind of specks on that 496 ?
Old January 5th, 2011, 05:14 PM
  #38
dsa2207's Avatar
4.185 bore, 4.500 stroke 6.800 rod
dsa2207 is offline
Old January 5th, 2011, 05:43 PM
  #39
how about the other stuff heads, intake , cam , headers or not, Did you
build it or who did thanks
Old January 5th, 2011, 06:01 PM
  #40
dsa2207's Avatar
I do not remember the cam specs but it's a very conservative street grind for torque. Stock big valve E heads, stock cast iron intake, quadrajet, W/Z manifolds, 3:23 posi, 2,400 stall converter. This car has A/C, Power windows, brakes and steering. Actually the 3:23 gear is way too much for this torque monster.
dsa2207 is offline
Quick Reply: who here has stroked there 455
