Windage tray brand preference
Old November 4th, 2012, 05:32 PM
csouth's Avatar
I'm about to button up the bottom end on my rebuilt 455 and looking to add a windage tray. I have a Canton Racing oil pan and Melling HV oil pump. I was looking at the DMR and the Milodon, anyone have a preference between the two? The price is basically the same, so I'm asking about fit or performance I guess.
csouth is offline
Old November 4th, 2012, 06:24 PM
380 Racer's Avatar
I use the Milodon.
380 Racer is offline
Old November 5th, 2012, 12:27 PM
csouth's Avatar
I was leaning that way, just see what other options were out there. The Olds market is so limited.
csouth is offline
Old November 12th, 2012, 01:48 PM
442rocketdave's Avatar
Csouth I have used the milidon and the Mondello and I like both but the Milidon was a better fit. I had to bend the Mondello a little, but both worked well. Its worth the effort and money. makes a real difference especially if your spinning over 7000rpm.
442rocketdave is offline
Old November 12th, 2012, 01:52 PM
citcapp's Avatar
My milidon had to be tweaked on my 455 with eagle "H" rods to fit correctly
citcapp is offline
Old November 13th, 2012, 07:48 AM
csouth's Avatar
I don't think mine will be spinning that high...lol I'm going to make the investment either way though.
My rods are stock, so I'm wondering if fit will still be effected?
csouth is offline
Old November 13th, 2012, 09:31 AM
380 Racer's Avatar
Actually I'm wondering if they are worth it. I have used the Mondildo and Milodon. The Milodon has better cutouts to put the oil back down in the sump as it's slung around. But every time the pan is taken off, the welds are broke on the tray and it's just kinda floating around down there held on by maybe one weld. I've been lucky a rod hasn't caught it.
Old November 13th, 2012, 09:41 AM
YIKES! I had one weld on my Milidon come undone and so I tig welded all of them myself and I have bought 3 of them over the centuries and never had another one come undone, Mondello's is always a tight fit and the first time I used one back in the 70s my crankshaft made the neccesary room. So I learned to double check the clearances and bend and grind and sand and all that fun stuff. But I know they help and so do the baffles.
Old November 13th, 2012, 10:33 AM
11.52 @116
jims2000lt's Avatar
I had to do the same with my Mondello tray with cut washers to space it out and notch for dipstick room.
During my freshen up this last winter I left it out and havent noticed a difference. Not turning 7000 rpm though.
jims2000lt is offline
Old November 13th, 2012, 11:54 AM
The_Jeremiah's Avatar
If your on a budget, get all the stuff from a toro engine, its not a good as the milidon setup, but its something!
The_Jeremiah is offline
coppercutlass
September 21st, 2012 12:00 PM
442Dave
August 29th, 2012 06:44 PM
Atdog
February 28th, 2011 12:38 PM
FixinIt
May 19th, 2008 05:03 PM
68rocketred
April 10th, 2008 11:39 AM
Quick Reply: Windage tray brand preference
