Yet another 455 question - main caps won't torque up
Old April 14th, 2024, 10:41 AM
PaulWinn's Avatar
Sorry for so many issues!
My 455 main cap bolts are not feeling right as I torque them down. They all acted the same up through 100 lbs with the 2 rears tightening up more quickly. Then trying to move up to 120 on all, the 2 rears hit it with very little rotation. The forward 8 bolts, most hit 120 ok but 2 or 3 won't go past 112-115 and turned almost a quarter turn with no increase. I have a light 10w40 oil on threads and under the head. I'm scared to go any more. Think these factory bolts have "yielded"? Maybe get a new set?
PaulWinn is offline
Old April 14th, 2024, 10:50 AM
Funkwagon455's Avatar
Check your bolts for “hourglassing”. I suspect that they are stretched. It might be time for some new hardware.
Funkwagon455 is online now
Old April 14th, 2024, 11:12 AM
Gary
VC455's Avatar
Paul,
Another possibility is that the cast iron tapped threads are yielding. With factory bolts this is more common than the bolts yielding.
This can happen if using a bolt lube with more "slipperiness" than the factory-prescribed lube.
If your lube is a synthetic oil, that would be an example.
Even if this happens, the block is not junk. You would buy and install thread savers which renew the grip.
Gary
VC455 is online now
Old April 14th, 2024, 11:16 AM
Thanks Gary, that is also a very viable possibility. Regardless, I’d appreciate it if you could share your findings for general experience purposes Paul. Thanks much.😃
Old April 14th, 2024, 11:30 AM
PaulWinn's Avatar
I happen to have a spare 455 block here so I torqued it up on the floor - similar spongy feeling on the 4 front caps but they all made it to 120. I'll swap these main bolts over to my build and see what happens. I loosened all on my first block and checked for visible issues - don't see hourglassing or bits of shavings on the threads. But I did not get the usual "crack" when breaking them free initially - think I have them simply oiled too much? This is embarrassing
PaulWinn is offline
Old April 14th, 2024, 11:46 AM
PaulWinn's Avatar
Just to be sure a previous Bubba hasn't pranked me - all 10 main cap bolts are identical, right? Even though the rear cap is shorter and get a ton more thread engagement, the front 8 taller caps use the same bolts and only use half the threads, correct?
PaulWinn is offline
Old April 14th, 2024, 02:40 PM
cutlassefi's Avatar
Don’t go from 100 to 120. You need a bigger spread than that for accuracy.
cutlassefi is offline
Old April 14th, 2024, 04:59 PM
BillK's Avatar
Also . . . . are you certain that your torque wrench is correct ?
BillK is online now
Old April 14th, 2024, 05:09 PM
PaulWinn's Avatar
Good point. It is a relatively new Craftsman 1/2" digital unit. Reviews were all good.
PaulWinn is offline
Old April 14th, 2024, 06:11 PM
BillK's Avatar
Might be worth borrowing one to compare it to. Personally I am not a big fan of digital torque wrenches but thats just me.
BillK is online now
Old April 14th, 2024, 06:19 PM
PaulWinn's Avatar
All is resolved but could have been a combination of things. I switched the main cap bolts from the other block, cleaned up most of the extra oils on threads and under bolt heads, torqued in a broader sequence (50, 75, 100, 120 vs 40, 60, 80, 100, 120). All bolts felt good and hit the numbers. Thanks for the help
PaulWinn is offline
jskorz
August 13th, 2022 06:47 PM
MO Olds 2022
July 14th, 2022 12:16 PM
Transam461
June 3rd, 2019 04:02 PM
AJFink
October 11th, 2016 06:17 PM
neoinbiz
October 24th, 2006 07:42 AM
Quick Reply: Yet another 455 question - main caps won't torque up
