1950 76/88 hood opening is too small
Old April 12th, 2019, 09:15 AM
50 Olds FAN
Jim Kniola's Avatar
My hood does not open very far at all. The springs hold it open but, even when I lift it as high as the hinges will allow, it is still a relatively small opening compared to the cars of the 60's and 70's that I had previously.
I feel that the hood is properly attached on my 1950 76 club coupe BUT it is a struggle to access the engine compartment. I have to duck my head and essentially lean on the fenders to work under that low-slung hood.
Is this normal? Is there any common solution that I could make that would allow that hood to raise into a higher "open" position?
Jim Kniola is offline
Old April 12th, 2019, 04:56 PM
Tedd Thompson's Avatar
Weak springs are common and bumps on the head are often with these old rides. When working on mine I usually use a prop stick to get a few extra inches higher and fewer bumps.. Unless the hood was installed some how differently and I can't imagine how and still have it work soon you will learn how to do the dip slide straddle hop as a reflex.... Tedd
Tedd Thompson is offline
Old April 13th, 2019, 09:43 AM
okie88's Avatar
I second the prop stick. I t doesn't take long to learn how dangerous those hood corners are !
okie88 is offline
Olds luvr
January 11th, 2018 09:37 AM
sumrhosr!
November 27th, 2017 09:56 AM
Olds luvr
November 9th, 2013 09:19 AM
71boosted
April 17th, 2013 07:40 AM
MJAKS462
May 23rd, 2010 08:13 AM
Quick Reply: 1950 76/88 hood opening is too small
