68 Cutlass Door Glass Stops
Old July 24th, 2023, 10:01 AM
Tims68Olds's Avatar
Ok, I'm sure this is a simple question but, where is the stop located in the door that keeps the window from going down too far? Mine goes to low and wants to push the outside felt up just a bit when I try to roll it up because glass goes slightly under it. It's not an issue if I stop the glass even with top of felt. I have power windows so would like it to stop exactly. I see a rubber block in the bottom middle area of the door that is fixed in place with no adjustment but that block needs replacing. Any source for that? Is that the stop? Thanks in advance.
Tims68Olds is offline
Old July 24th, 2023, 02:43 PM
BackInTheGame's Avatar
Which body style?
BackInTheGame is online now
Old July 24th, 2023, 05:13 PM
Tims68Olds's Avatar
Convertible
Convertible Cutlass S
rcwjr
May 31st, 2021 10:25 AM
spate51
Body work
August 1st, 2012 04:18 AM
devmar07
February 27th, 2012 05:41 AM
Gary's 2 442-S
Body work
16
February 12th, 2012 09:22 AM
rocketdownunder
September 16th, 2011 02:06 PM
Quick Reply: 68 Cutlass Door Glass Stops
