71 Supreme fender installation
Old November 27th, 2023, 03:37 PM
JS71SX
JS71SX's Avatar
Hello all - I am almost done with my car, I am having a royal pain trying to get my OEM fenders reinstalled. The car is 100% original, I pulled the fenders off about a year ago to have car painted. Does anyone have any tips/tricks on how to align this up - having a very difficult time getting the fender aligned at the top corner of the door. Cannot get the crease to line up between fender and door, unfortunately I did not record what shims went where when I took it apart. The car was very straight before taking it apart and it has all the original sheet metal - this is an Arizona car with zero rust. I appreciate any help - looked on YouTube but found nothing too specific. Than you
JS71SX is offline
Old November 27th, 2023, 04:14 PM
The obvious to me would be ensuring the car is not sitting on jack stands but instead sitting on the ground. Easy to introduce flex, twist, etc. sitting on stands.
Vintage Chief is offline
Old November 27th, 2023, 06:45 PM
tkcutlass's Avatar
I had difficulties as well you may find the posts below may help
https://classicoldsmobile.com/forums/body-work-67/70-72-passenger-fender-stick-upward-back-169126/
​​​​​​https://classicoldsmobile.com/forums/major-builds-projects-72/70-cutlass-supreme-convertible-my-first-frame-off-142804/page9/#:~:text=%C2%A0%20%23-,358,-tkcutlass
tkcutlass is online now
Old November 28th, 2023, 04:28 AM
JS71SX
JS71SX's Avatar
No The car has been on the tires since installing all the sheet metal and it is on level ground
JS71SX is offline
Old December 6th, 2023, 06:15 PM
JMJ-RIP's Avatar
If you also had the core support off, you'll need to square up the the fenders using an "X" pattern from the top cowl bolt to the same spot on one of the core support fender bolts. I would also make my alignments with the hood on as it will need to be involved in the alignment.
Shims, there could be a couple different shaped ones and there is typically a couple different thicknesses. They can exist at the top cowl bolt, the upper cowl side bolt and the two lower cowl bolts (I would tighten the lower bolts last). The lower two bolts can also be used to open or close the vertical contour a little.
JMJ-RIP is offline
Old December 6th, 2023, 06:43 PM
Rodney
cdrod's Avatar
I had issues squaring my front fenders and measuring diagonally across the fenders is the only way to get this correct. Here's a link to my build thread showing how I did this.
https://classicoldsmobile.com/forums...6/#post1409126
Rodney
cdrod is offline
olsn500
November 12th, 2018 07:07 AM
Hurst/Olds 73/74
August 23rd, 2016 05:24 PM
Rocketbrian
Body work
June 14th, 2015 05:45 PM
Del70
March 25th, 2015 03:21 AM
JS71SX
February 23rd, 2014 07:18 PM
Quick Reply: 71 Supreme fender installation
