Cowl Tag : Help Reading It
Old March 12th, 2010, 11:42 AM
justagirlfromla's Avatar
Can someone tell me what this means? What original color, trim, or any info? Much appreciated
justagirlfromla is offline
Old March 12th, 2010, 12:01 PM
Trying to remember member
wmachine's Avatar
70-33687 70 Cutlass S Holiday Coupe
BF 00782 Fremont CA body build sequence number
943 Blue Cloth bench interior
20 20 Azure Blue top and bottom paint
09D Fourth week September build
wmachine is offline
Old March 12th, 2010, 12:02 PM
OMG You are flippin' AWESOME THANKS!
Old March 12th, 2010, 12:10 PM
If you want to find out if the engine is orginal to that car, there is a small pad on the block below the #6 head casting number and below the #1 spark plug, which is the plug on your far left standing on the drivers side of the car. This has a V.I.N. derivative stamped on it. It will tell the year of the engine block, and help match it to your car via the V.I.N. at the base of the windsheild @ the bottom of the dash on the drivers side. I f this number
1969w3155 is online now
Old March 12th, 2010, 12:11 PM
oops! if this partial number matches up with the VIN , then it is origianl to the car.
Old March 12th, 2010, 12:15 PM
Just to clarify,
It's above the unpainted exhaust manifold you asked about and below the head numbers your found. It's not very big and often gunked over.
Jamesbo is offline
Old March 12th, 2010, 12:23 PM
Yea i can only see the last few parts of it, part of the alternator clampy-thingy- is covering it.
Edit: The VIN ends in 3275 and the part i can see on the engine ends in CFD or CF0 or CFO
Old March 27th, 2010, 11:49 AM
blueRAYwhale's Avatar
Smile "I'll try to decode that tag as well"
Originally Posted by justagirlfromla
Can someone tell me what this means? What original color, trim, or any info? Much appreciated It does look as though they got it right. I will post it later, this is a great site.
blueRAYwhale is offline
preacherinseville
July 8th, 2012 03:05 PM
preacherinseville
July 8th, 2012 02:36 PM
preacherinseville
July 8th, 2012 02:30 PM
71cutlasssx
December 20th, 2009 07:19 PM
bulldog
May 19th, 2008 01:29 PM
Quick Reply: Cowl Tag : Help Reading It
