Door weight?
gotcha, after i stripped out my doors they dont sag anymore and are light as a feather, close with one finger. still need to order the hinge renew kits though. unless i leave out the glass and regulators and just drive the car on nice days with all the windows down weigh the reg and a piece of glass and a handfull of sand and you should be close to what was pulled out.
I still need to install my hinge kit.... I am in the middle of a small re&re on the house right now so it will be later this week before I get to it
and in case you missed my post Stan due to you not having your pot of coffee yet my stuff is all packed away
but I do get 220 to my garage this week which my wife likes instead of using her dryer plug all the time lol
my glass and regs are available, hardtop but should be close enough. i could get you an approx weight? and yes i did see yours were packed away, so are mine but they are packed away in my shop and easy to grab if no one else comes forward with a number
Why sandbagging? I did not know you needed to do this to just to install the door and align the hinges...
Am I missing something?
you guys suck I just got milk in mine lol
Rob if you hang and align the door without the full weight of glass and guts the door has a risk of sagging a little and throwing the alignment out once everything is back in it
my car has never been gapped since I have owned it so I need to make sure I have everything set before I tear it all apart again for paint prep plus I had to replace one of my original doors as well
ok wes, the things i do at 7 am makes my wife shake her head. borrowed her weight watchers scale with the digital readout. grabbed a vent window and frame, side window, and regulator. 259.4 lb, then without carparts, 231.6 lb, hey, i was fully clothed and wearing shoes, comes to 27.4 lbs. add inside outside doorhandles, door panel, arm rest, maybe 35lbs? yup, small child
good luck wes, now im off to the vintage swap meet for a quick walkabout, then to the uncle in laws to finish some landscape ties that we didnt finish yesterday, home by noon i hope. may get some painting and more sanding done today i hope
Joe good thing I have more than one Kid thanks
on a more serious note the hinge pin rebuild kit I got doesn`t work..........
I need 2 5/8 pins for my hinges but the ones I got are 2 3/8
I measured 3 sets of hinges to make sure I didn`t have a bad hinge
does anyone know of a correct pin I can use?
I did some searching on some other forums.......
It seems the repop kits are all to small for the hinges
So what you have to do is set the pin with a chisel
So stuck my hinge in the vise and drifted the pin with one of my dull chisels worked alright..... rehung the door with no issue
