Electolytic rust and paint removal
Old July 14th, 2015, 08:38 PM
Photoshop God
DewChugr's Avatar
I posted this on the Olds facebook page recently but I thought I'd share it here.
The bucket I use is a 5 gallon plastic bucket like you can get at lowes and other places. I added 4-1/2 gallons of warm water then put in 2/3 cup of arm and hammer washing soda. It's in the laundry detergent aisle. Stir until dissolved.
I put those two pieces of steel in hanging on a dowel. Make them so they don't touch the bottom. I bought 3 feet of 10-2 wire from lowes. I attached one end of the wire to each piece of steel and stripped about an inch of insulation off a few inches from one end to connect the positive clamp of the battery charger.
The other wire I stripped a few inches off each end. One connects to the negative battery charger clamp and the other to the piece you want to remove the rust from.
I wrapped the wire around that piece of wood and put the wire through one of the holes. The I set it into the bucket so it is just low enough to be submerged and not touching the bottom.
Do not let your pieces of steel touch the part.
I set the charger on 10 amps and let it go over night. When it's working you will see small bubbles like in the video. Those contain hydrogen which of course is extremely combustible (see Hindenburg). ONLY DO THIS OUTSIDE.
I can't tell you how long it takes. I put that piece in around 3 or 4 and took it out this morning. Then I put the spindle in at about 10 and took it out about 5. You can take it out periodically and rub it down with a scotch brite and stick it back in. BE SURE to unplug your battery charger before moving parts around.
You can use whatever steel you want, some use rebar. It sacrifices it's self in the process and should eventually disappear. They say it works by line of sight so you want at least one piece on each side. DO NOT use stainless steel. It doesn't disolve but it does give off poisonous gas. Some people do this in kiddie pools for larger parts.
It will remove rust and paint. I would not recommend putting anything other than steel/iron in there. If you have parts with aluminum or other things I would remove all that or look for another method. Treat it with something as soon as you dry it or you will get flash rust.
So far I've don the spindles, hubs, tire iron, jack base, some nuts and bolts and I'm working on a bumper mounting bracket now.
I don't know if you'll be able to see the photos since they're on FB.
Facebook Post
DewChugr is offline
Old July 15th, 2015, 10:06 AM
72 Olds CS
RetroRanger's Avatar
I tried that it works good. What did you do after you take the parts out? I found stuff flash rusts real fast w this method.
RetroRanger is offline
Old July 15th, 2015, 11:06 AM
Photoshop God
DewChugr's Avatar
It does flash pretty quick. If you dry it real well right away it takes a little longer, but I try to at least spray a light coating of primer on them. Tonights the problem, I'm doing the large bumper mounting bracket and only part would fit in the bucket. I'm not sure if I can get all of the other end that hasn't been done submerged. I might have to get a bigger bucket.
I also want to try zinc plating for the nuts and bolts.
DewChugr is offline
Old July 15th, 2015, 01:18 PM
Perkolator's Avatar
pretty cool, thanks for sharing!
I tried this last year with so-so success on a steel wagon I rebuilt for my son. I guess it was sitting in a field for unknown amount of time and was quite rusty when I got it. I did mine in my city issued recycle bin (60+ gallons) and was able to do half at a time (wagon can fit 2 adults!)
My neighbor who was working on a 1930s Chevy told me about the technique - said some people even go as extreme as wheeling their car body into an above ground pool, filling it up, then linking car batteries to do the electrolysis!
Perkolator is offline
Old July 15th, 2015, 03:46 PM
RROLDSX's Avatar
If you use graphite plates as electrodes you won't get the red scum and your part won't flash rust.
RROLDSX is offline
Old July 15th, 2015, 05:25 PM
Gerald Nickels's Avatar
I don't have the rust problems they have in the East but here I use Rust Mort sold in paint stores and works great in killing rust just like your dipping.
Gerald Nickels is offline
Old July 15th, 2015, 07:26 PM
Photoshop God
DewChugr's Avatar
I've heard that. Any idea where to get some?
I am doing the large bumper brackets and I am amazed at how well it is working on them.
DewChugr is offline
Old July 15th, 2015, 08:52 PM
72 Olds CS
ebay has a good selection of them be sure to read the sizes as some are quite small
Kyle's 77 Cutlass
Paint
57
June 28th, 2015 01:05 PM
shamusj
December 22nd, 2014 09:21 AM
Delmont 88 PA
Body work
May 25th, 2012 09:28 AM
Del70
May 22nd, 2011 01:31 PM
easytobedead
Paint
April 10th, 2009 06:16 PM
Quick Reply: Electolytic rust and paint removal
