Power Antenna Nut Removal Tool
Old February 2nd, 2018, 02:08 PM
77toronado's Avatar
Man, where to put a thread about a Toronado radio power antenna? Electrical, Interior, Bodywork, Toronado??
Does anyone know offhand the specific, right tool to remove the power antenna nut for a '77 Toronado? The tapping it with a small screwdriver in the slots trick isn't cutting it - it's about to screw it up.
Usually, GM factory manuals are filled with statements like "Use J-3490 philips head screwdriver or equivalent." Not in this case. Not even a listing at the end of the chapter of the special tools used within the chapter.
I've seen sets on eBay and amazon, but most aren't specific on what they do or don't fit. There's a set from Lisle (#29650) that has a socket for "GM 77-current". Sunex #392106 shows the same thing on Amazon. Their #392107 looks bigger, but fitment is for '90s Chevy trucks, supposedly
This worries me because anyone with a '77 or '78 Toronado knows our cars a lot lot more kin to '76 and older than '77 and newer GM cars, which all had big changes that year. The AC system and entire dash are good examples.
Anyone had personal experience with this?
Feel free to move this thread to a more appropriate section, if needed.
http://www.lislecorp.com/divisions/p...s/?product=155
Amazon Amazon
Amazon Amazon
77toronado is offline
Old February 3rd, 2018, 06:29 PM
Yellowstatue's Avatar
You could try a pair of needle nose pliers with a 90 degree bend or look at Snap-on tools. They show five different sockets, but you have to start a Go-fund-me web site to pay for them!
Yellowstatue is offline
Old February 4th, 2018, 08:11 PM
77toronado's Avatar
Here are a couple of pictures of the bezel I'm trying to remove.
I'm not sure that the snap-on sockets are any different than the Lisle set. Let's face it, I'm not sure of anything
Old February 4th, 2018, 08:36 PM
That retainer has six notches so the four prong tool in the Amazon links won't work. Maybe one of the two pronged tools in the Lisle set would work, but no idea which one, if either .
Fun71 is online now
Old February 5th, 2018, 10:14 AM
77toronado's Avatar
Yeah, when I snapped the pictures from my parts car, I realized I had a six way bezel on there.
My main car had an aftermarket antenna installed when I got it. It croaked on me, so I'm trying to go with OEM, or at least with OEM hardware on top of the fender.
I was working on a car in a junkyard last week and having no luck getting the bezel lose with the tapping on a small screwdriver method. That started my search for the right tool to do the job. It didn't register that it had 6 slots when I created the post (my cars aren't where I live during the week).
I'm batting 1.000 here lately.
Old February 5th, 2018, 02:36 PM
Snap-on catalogue states that socket S9625C services 1977 and later GM cars. A three pronged tool might work also.
Old February 5th, 2018, 05:34 PM
77toronado's Avatar
Yep. Most of the tool sets show one for '77 and up GM. That Snap-On is a four prong socket. I have no doubt that it fits '77 and up Caprices, Impalas, etc.
The Toronados were pretty much holdovers until the new design came in for 1979. More than likely, what ever worked for 1975 or 76 would work like a champ on this. I just can't find what it is.
I appreciate everyone helping out with this.
Old February 6th, 2018, 03:13 PM
Fred Kiehl's Avatar
This tool could be modified to fit a six slot nut:
Amazon Amazon
You can file off two of the pins in the circle, and if necessary file the pins thinner so they fit the slots. You should be able to get them at a local parts store as well.
You can also get an adjustable spanner with replaceable pins, or file the pins to fit the slots.
Amazon Amazon
Amazon Amazon
Amazon Amazon
Fred Kiehl is offline
Old February 6th, 2018, 05:55 PM
77toronado's Avatar
Thanks Fred.
The pin wrench idea is interesting. It looks like that may be the path I'm going to have to take. I foresee some pin filing in my future.
Platinum69
February 19th, 2017 06:23 AM
35tac
December 21st, 2016 03:41 PM
bob p
June 4th, 2015 01:53 PM
ROCKET VAPOR
June 20th, 2011 06:50 PM
hialeah56
April 13th, 2011 07:50 PM
Quick Reply: Power Antenna Nut Removal Tool
