rust removal
Old April 22nd, 2014, 10:41 AM
mike74442's Avatar
rust removal
I'm looking for something to get rust off of my engine bay so I can paint. I don't want to sand blast it it's to messy. What are some good acids or brands?
mike74442 is offline
Old April 22nd, 2014, 10:45 AM
Chevy budget Olds powered
coppercutlass's Avatar
Wire brush it and knock the scale rust off and either use the chassis saver process or the por-15 process. Both can be applied directly over rust but they also recommend using the etch agents and what not to insure that no rust will come back.
coppercutlass is online now
Old April 22nd, 2014, 10:47 AM
mike74442's Avatar
Sweet thank you we'll see how this goes.
Old April 22nd, 2014, 02:03 PM
RROLDSX's Avatar
There's also Navy Jelly if you want to use an acid.
RROLDSX is offline
Old April 22nd, 2014, 03:53 PM
mike74442's Avatar
Just got some navay jelly, are there any risks besides the warning on the label saying I should paint it within 48 hours? Isn't there a way I could neutralize it after I use it?
Old April 22nd, 2014, 05:38 PM
RROLDSX's Avatar
I believe it is an acid so I suggest rinsing well with soap and water once completed. I think the warning is to paint it before it rusts again. Rust converters work well too. Go easy with it as I think it was developed for working on ships.
RROLDSX is offline
Old April 22nd, 2014, 05:44 PM
Rodney
cdrod's Avatar
I've been using EvapoRust which works really well. I follow up with a galvanizing "Fast Etch" from Eastwood which prevent the flash rusting until you paint it. The EvapoRust can be reused but with each use it's potency is diminished. I think EvapoRust even comes in a gel formula as well which would work better on vertical surfaces. It's important to thoroughly degrease first because EvapoRust won't cut through the grease.
cdrod is offline
Old April 22nd, 2014, 05:49 PM
mike74442's Avatar
All right I'm gonna use the navy jelly and if that doesn't work I'll try the evaporust. Would it be ok if I used gasoline to get the grease off and then rinsed it with water?
Old April 22nd, 2014, 06:28 PM
Id much rather use diesel to soak the grease then power wash it. Gasoline fumes are enough to make me uneasy diesel fumes stink but ignite at a higher rate.
Old April 22nd, 2014, 06:44 PM
RROLDSX's Avatar
I tried the Evaporust with some success but I think the electrolysis with graphite plates works much better and is much cheaper. I'm using a large rectangular bin I got from HF (black/yellow) that I can do fairly large parts in. I'm fitting 4/5's of a 15" wheel in it. The graphite prevents the red slime from developing. Use a degreaser like OilEater instead of diesel or gas. You can spray it on like Windex and wipe/rinse it off.
RROLDSX is offline
Old April 22nd, 2014, 08:08 PM
mike74442's Avatar
Ok oil eater it is thank you for the tips 40 year old rust and corrosion aren't fun thing's to deal with.
Kyle's 77 Cutlass
Paint
57
June 28th, 2015 01:05 PM
diesel7477
Body work
July 5th, 2012 12:28 PM
Delmont 88 PA
Body work
May 25th, 2012 09:28 AM
Del70
May 22nd, 2011 01:31 PM
easytobedead
Paint
April 10th, 2009 06:16 PM
Quick Reply: rust removal
