wheelwell prep
wheelwell prep
wondering what your guys think on this
going to tackle my wells here and I have found some surface rust between the inner and outer seam
I picked up some rust converter and was going to put it in there then seam seal it then put the bed armour on
I just don`t want an issue down the road ..
How bad is the rust your talking about? Got a pix? I only ask because everyones idea of surface rust is different. I'm from upstate ny and I have been doing body work for over 25+ years now and I have seen lots of rust repairs in my days. so I would love to help you in any way I can.
Got a chance to shoot a couple of pics tonight
hopefully you get a general idea of what I`m talking about
rear side of wheelwell
and a couple of the front
Wow that's clean I live in the rust belt so seeing pix's like these makes me drool. Honestly wire brush the areas and then use your converter. Hell even around here a car with that little rust would out live us all. I'm going to show you what I usually start with when I work. I'll be right back.
Here's a good example of what i have to deal with when I get a car into work on.
After a day of tear down: Both rear quarters had to be removed and trunk extensions were bad to. Probably should have siad there were no rear quarters or trunk extensions because honestly I din't have much to remove. LMAO!
Seven months later:
Seven months later:
come finish mine lol
I am no body man by far that is why I asked about the rust
the thing that would drive me nuts would be to have the rust burst through 6 months after the car is on the road
TRW
September 17th, 2010 09:42 AM
