Will a 1969 door skin fit on a 1968 door frame?
Old July 7th, 2013, 09:38 AM
BCBigBlock's Avatar
Hi All,
I have a 68 Cutlass 2 door hard top and I need to replace the door skin on the drivers side door. I have been unable to find a 1968 door for the car but i have found a few 1969 doors. My question is if we were to skin the 1969 door would it fit on the 1968 frame?
Thanks for everyone's help.
Ryan
BCBigBlock is offline
Old July 7th, 2013, 10:48 AM
Originally Posted by BCBigBlock
Hi All,
Ryan
Other than some notching around the vent window frame, yes. Compare the two carefully - I think others have been able to modify the complete 69 door shell to accept the 68 vent window and used it without the trouble of transferring the skin.
joe_padavano is online now
Old July 7th, 2013, 01:04 PM
BCBigBlock's Avatar
Thank you very much for your help.
Ryan
Old July 7th, 2013, 06:28 PM
allyolds68's Avatar
I'm pretty sure the 69 door lock comes up in a different place too
allyolds68 is offline
Old July 8th, 2013, 07:56 AM
Mike,
Are you talking about the lock cylinder, the lock **** on the inside, or the actual latch mechanism?
Old July 8th, 2013, 09:45 AM
allyolds68's Avatar
Mike,
The lock **** on the inside.
I ordered a set of 68 door panels for my car from Legendary a couple of years ago. About when they were supposed to be delivered I got a call from them saying they used the wrong uppers and the lock hole was located in the 69 position instead of the 68. They told me there was enough of a difference that the 69 location wouldn't work on the 68. The made a new set of panels and I got them two weeks later. I've never put the two years next to each other so I can't tell you for sure. It may have just been a story but they had no reason to lie because I wasn't hounding them or anything.
I used a donor 69 door for patches in the lower front and rear corner of my 68 doors (where they always rust) My door skins had very little rust so I didn't need to replace them.
Old July 8th, 2013, 01:51 PM
BCBigBlock's Avatar
I have found a set of 69 doors so I think I may just switch the whole units and run without the vent windows. I have always liked the one piece glass look over the vent windows. This car is meant to be a really fun driver, it is never intended to go back to stock. Installing a posi unit out of a 68 GTO this weekend.
Old July 28th, 2013, 06:09 AM
allyolds68's Avatar
Just following up on this thread because I found that the interior door panels definitely are not interchangeable without a lot of work. The lock **** location is different by at least 6" and obviously the vent windows aren't on the 69. As Joe said the skins themselves probably would have worked with a little tweaking
BTW if you're still interested in the skins these were pretty clean. The door frames themselves, not so good
RandyS
June 25th, 2015 06:11 PM
Danp76
Body work
April 13th, 2012 01:07 PM
67 Olds 442
March 15th, 2012 11:15 PM
1971 442 convert
Body work
January 15th, 2010 12:36 PM
dallaire1
Body work
April 8th, 2009 04:42 PM
Quick Reply: Will a 1969 door skin fit on a 1968 door frame?
