65 Starfire brake booster interchangeable 88/98 ?
Old April 9th, 2007, 07:06 PM
plasma98's Avatar
Talking 65 Starfire brake booster interchangeable 88/98 ?
Hi guys: New owner of a 65 Starfire that sadly needs a power booster. I have been doing some searching through local suppliers, and Cardone has listing for the 88/98 but not for Starfire. Now I was thinking that these three have so much in common brake wise, that I could likely use the 88/98 one. Has anyone tried this or found a better solution? I appreciate any help you guys can advise.
Cheers!!
Plasma98
plasma98 is offline
Old April 10th, 2007, 07:01 AM
plasma98's Avatar
Thanks Paul
As I thought, thanks for confirming, Paul.
Plasma98
plasma98 is offline
Old April 10th, 2007, 08:09 AM
Just be careful about the pushrod length where it presses on the master cylinder piston. The single master cylinders (66 and older) use a longer pushrod than the dual master cylinders (67 and later). The two are not interchangeable.
joe_padavano is offline
Old April 10th, 2007, 09:30 PM
plasma98's Avatar
Thanks Joe. every bit of info is welcome. Have ordered the 88/98 booster, and surprisingly they had stock in Canada! Heheh..what a coutry <grin>
I'll let you guys know how the final out come goes...then its power frigging window repair time.
Cheers
Plasma98
plasma98 is offline
Old April 19th, 2007, 08:02 PM
plasma98's Avatar
Hey guys:
Well, the booster is in with a new master cylinder and it worked perfectly.
Just for those who care .
Cheers!!
Plasma98
plasma98 is offline
Old April 20th, 2007, 12:06 PM
Mister's Avatar
Thank you for letting us know the results.
I hate it when I see all this advice given, and we never hear back from the advisee. It is nice to know what worked and what didn't.
Mister is offline
zodiacblueS
Brakes/Hydraulic Systems
44
October 12th, 2014 03:22 PM
1Starfire
June 29th, 2009 09:48 PM
formula
March 22nd, 2009 09:46 PM
toms1966rgtop
February 12th, 2009 06:19 PM
ss427
March 30th, 2008 10:52 AM
Quick Reply: 65 Starfire brake booster interchangeable 88/98 ?
