Brakes stay lit
Old July 19th, 2008, 10:39 PM
projectheaven's Avatar
Brakes stay lit
Hello,
This may be a known common problem but when i press the brake pedal I have to put my foot behind it to pull it back towards me to get the brake lights to cut off.Someone told me it may be my brake booster and I need a new one.Do you think thats the problem?
Any help would be appreciated.
Thank you
projectheaven is offline
Old July 20th, 2008, 07:03 AM
Originally Posted by projectheaven
Hello,
Thank you
Brake booster? Not hardly. If the brakes work correctly then you simply need to adjust the switch on the brake pedal. It's under the dash, attached to the bracket that the break pedal pivots on. Just unplug the wires and screw the switch in a little, then reconnect the wires.
joe_padavano is offline
Hairy Olds
January 2nd, 2014 03:56 PM
oxford
October 17th, 2013 09:24 AM
Winger67
October 9th, 2013 11:58 AM
Delta88royal
August 20th, 2011 06:26 PM
russell-t
Brakes/Hydraulic Systems
April 30th, 2011 05:56 AM
Quick Reply: Brakes stay lit
