Disc conversion
Old January 23rd, 2009, 12:37 PM
Wilson05's Avatar
Disc conversion
I just recently got my 1968 Olds Cutlass S back after being away from her for the past 9 years. I am looking at replacing the front drums w/ ad disc conversion. I've noticed the prices for a complete new kit to be a little pricey. Is it worth spending that kind of money on a new kit or can I get the same performance with a little more blood, sweat and tears find used parts for such a project? And what other vehicles out there might bolt up to my '68 if I find something in the junkyard? Thanks for all your help.
Wilson05 is offline
Old January 23rd, 2009, 01:02 PM
kaz442's Avatar
I would look for any 69-72 A body in the junk yard. While your there grab the proportion valve and the master if it looks worth it(if not just buy new). JKaz
kaz442 is offline
Old January 23rd, 2009, 01:11 PM
hamm36's Avatar
I thought it was worth it, only because i did not want it to take a year finding parts here and there, shipping, or spending days milling in a bone yard. Then you need some new parts: bearings, rotors, MS, lines to fit, etc... Your year kit might come with brake lines from MS to old lines, but ask before you buy. Or you can bend your own... This is day'sha-voo... You will probable find some good used and go with that. I did not wait $599 shipped with braided lines and slotted rotors.
hamm36 is offline
Old January 23rd, 2009, 03:02 PM
Try the search function on this site:
https://classicoldsmobile.com/forums...sk-brakes.html
joe_padavano is offline
Old January 23rd, 2009, 03:03 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Check the For Sale section on this site. There is a whole setup for $250. Location might be a problem for you.
redoldsman is online now
Old February 17th, 2010, 09:29 PM
Just A BaBy {:
easytobedead's Avatar
well just wanted to know If there was any way to change my 1984 hurts/Olds drums to disk in the rear?
found this on line but i don't know
http://www.performanceonline.com/sto...27&cat=0&page=
easytobedead is offline
Old February 18th, 2010, 01:53 PM
Just A BaBy {:
nada?
Old February 18th, 2010, 04:42 PM
#1CutlassSupreme's Avatar
I did a 4-wheel conversion on mine and it was totally worth it! The booster, proportioning valve, lines, E-brake cables, spindles, and calipers in the kit all bolted right up to the factory spots. I got my brakes from MBM brakes.
If you do the rear you will have to pull the spider gears and axles to remove the bracketing for the prop valves on the drums. This is where you end up mounting the new caliper brackets. You will also have to weld on the new brackets to the rearend for the soft lines to hook in to the factory hardlines. This will also require a little bit of cutting on the hardlines and re-flaring of the tubes. In all honest, you could get the whole job done in less than a day if you have access to a lift.
In terms of performance; MUCH better! The drums felt like I had to plan how far back I was going to hit the brakes, but the disks have a good grab and never give me any problems. They're not slotted rotors or fancy calipers, but they work just fine!
#1CutlassSupreme is offline
Old February 18th, 2010, 05:53 PM
Jaybird's Avatar
Question
I too, am looking to convert my car - Delta 88 (B body) to power front disc brakes.
I believe that I can purchase the needed items, off-the-shelf, but I don't know
the part numbers, etc. I've asked around to a few mechanics.
They say it can be done.
What are the exact parts I need? I would like someone to give me the part numbers!
Could you take a minute or two and give me the part numbers?
Your help will be greatly appreciated!
Thanks in advance for your help, and Thanks for this great forum!
Jaybird
Jaybird is offline
Old February 18th, 2010, 06:38 PM
Just A BaBy {:
ty for the info,2 bad thing for me,no lift an don't know how to weld but, I do have some one who can weld so Ill take it to him for that.
Mocephus
October 1st, 2021 09:45 AM
68droptop
Brakes/Hydraulic Systems
March 31st, 2009 06:10 PM
Want-A-Vert
July 16th, 2007 07:50 PM
crazyiball
January 18th, 2007 06:40 PM
Want-A-Vert
January 4th, 2007 07:19 AM
Quick Reply: Disc conversion
