Drum interchange
Old July 4th, 2011, 04:06 PM
milners32's Avatar
Drum interchange
Can anyone tell me if and what drums from other GM or Olds applications will interchange with the drums from a 1955 88?
Thanks!
milners32 is offline
Old July 4th, 2011, 05:03 PM
Proud Viet Nam Veteran
redoldsman's Avatar
You might try checking Kanter's website and see if they list the same part number if they carry them. Maybe Pontiac or Buick. Just a thought.
redoldsman is offline
Old July 4th, 2011, 06:33 PM
66400's Avatar
Oldsmobile only, rear drum 1952-1956. Front hub and drum assembly 1954-1956.
Henry
66400 is offline
Old July 5th, 2011, 05:00 AM
milners32's Avatar
Henry
I found a 57 Olds at my local junk yard, so the drums on it will not fit my 55?
Dude
Old July 25th, 2011, 05:57 AM
milners32's Avatar
Maybe this will help someone else out who needs front drums for a 55.
57 front drums will fit on a 55 however, you have to use the outside race and bearing from the 55 in the 57 drum and you need both sets of washers that have the tongue for the spindles.
The 57 spindles are a little bigger in the outer diameter than the 55 but if you use the outer race and bearing from the 55 it will fit the drum and the spindle and, they fit a little deeper into the drum so you need the washers from the 57 and 55 in order the get the castle nut up to fit the hole for the cotter pin. You will also need the 57 dust covers as well.
I do not know if the 57 drums will interchange with other years that interchange with the 55 but, I suspect they would.
I found two front drums from a 57 at my local junkyard, they let me pull one and take it home to be sure it fit, it did so I went back and got both for $40 and had them
turned for $16.
matviar
October 22nd, 2014 11:12 PM
oldsfamily
Brakes/Hydraulic Systems
September 1st, 2014 01:23 PM
455Olds
December 8th, 2013 08:16 PM
Oldssupreme
January 29th, 2013 07:03 PM
1carsick
23
October 2nd, 2012 05:50 PM
Quick Reply: Drum interchange
