Master Cylinder Movement
Old December 24th, 2013, 10:11 AM
Nighthawk's Avatar
Was having trouble getting a completely solid pedal feel on my '77 cutlass even after multiple bleedings and replacing the wheel cylinders which appeared to be leaking. Everything is new from the master cylinder to each wheel. Took another shot at bleeding the system and noticed that the master cylinder seems to move a little when braking forcefully. Could this be the cause of some very, very slight brake pedal sponginess? I was having trouble determining if the movement was originating at the firewall or at the connection between the master cylinder and vacuum booster. Anyone else ever notice movement like this?
Nighthawk is offline
Old December 24th, 2013, 11:21 AM
They all do that, at least every one I've seen.
MDchanic is offline
Old December 24th, 2013, 01:41 PM
Nighthawk's Avatar
Well, that's good to know. I thought maybe I had a structural problem! Thanks
ent72olds
April 23rd, 2013 10:31 PM
Redog
May 11th, 2011 03:57 PM
Ranzan
Drivetrain/Differentials
September 16th, 2010 02:26 PM
65Delta88
September 19th, 2008 05:26 AM
martine
Brakes/Hydraulic Systems
February 5th, 2004 10:28 AM
Quick Reply: Master Cylinder Movement
