Vaccum canister help!!!
simple question.. where do i connect the vacuum line to the canister? from the back of the carburetor( i have a edelbrock 600cfm) or from the engine where the brake booster is connected?
does it make sense pls help?
should go to where you have manifold vacuume at idle. The other one is ported vacuume. I can't remember which is which. Just put a gauge on it to check.
Edit: use the big port where the brakes go. I thought you were talking about the factory bulb for the A/C that sits on the firewall.
ok.. i bought a vacuum canister for my power brakes...( http://www.hawaiiracing.com/shop_ima...84a64d5e9c.jpg )
now i dont know if to hook it up from the manifold vaccum or from the back of the carburetor?
ok so where does the brake booster gets the vacuum from the engine? im asking if i should connect it there or in back of the carburetor?
i hope it makes sense
or to make it easier.. how do i connect the vacuum canister for my power brakes?
this one http://www.hawaiiracing.com/shop_ima...84a64d5e9c.jpg
Booster will now be hooked to the new canister. The canister works as a piggy back storing the vacuume that may not be there in the engine with a big cam. I personally prefer a well set up manual brake system but thats just me.
Okay, the original brake booster gets its vacuum off a rear port on the intake manifold.
I circled it in purple on the attached picture. This a a 1972 350.
That metal line runs over to the booster where a rubber hose connects the two.
^^ thanks you soo much!!!
my original vacuum canister was not connected ,.. so when i bought this one my neighboor was telling me that it was
from the back of the carburetor to the canister
and from the canister to the brake booster.. and he got me confused
What would this have been?
Are you talking about the booster (9" can behind the master cylinder)??
There was no factory "vacuum canister" on the 72 for the brakes.
The tube was run from the manifold (circled) to a rubber hose to the brake booster.
I am assuming your engine is a 72 stock Olds?
warrior71
February 5th, 2009 03:20 PM
