fuel tank selector valve failure
Old February 3rd, 2017, 06:51 AM
JimD75's Avatar
Hi everyone,
Recently notced that my engine started to misperform. I mean, everything is fine with the engine, no misfiring or something. Yet, I noticed the power loss. After checking the codes, I discovered the fuel tank selector valve failure. I have already checked what kind of valve I need (for my 1994 Bravarda it is a 6-port valve, listed as FV-5 type).
Anyways, before I take my Bravarda apart and start searching for what is wrong with it, wanted to ask you folks here, if anyone did the replacement of this valve? If so, was it hard? Because after reading the instructions online, I was under impression that I'll cope with it, just wanted to ask someone who was in the same situation...
JimD75 is offline
Old February 6th, 2017, 12:53 AM
JimD75's Avatar
Okay, here is an update. I have already found an aftermarket valve online, so decided to give it a try and ordered one (https://www.carid.com/fuel-tank-selector-valves/)... Already printed out an instruction for myself, so once the valve is delivered will get it fixed...
JimD75 is offline
Old February 14th, 2017, 10:49 AM
jcdynamic88's Avatar
i have a 94 bravada and had the tank out recently and didn't see any valve like that.That looks like a valve for something with two gas tanks.the most common thing for loss of power on those old 4.3s is the fuel pressure regulator.i would check fuel pressure first.
jcdynamic88 is offline
Old February 14th, 2017, 11:44 AM
What is the initial problem? You mentioned that there wasn't a misfire or poor performance. If there is a code indicating your fuel tank selector valve isn't functioning properly then what are the symptoms?
Before replacing the fuel tank selector valve check for 12V at the valve when you actuate the switch on the dash. If you have 12V and the valve doesn't actuate then you know the valve is bad.
Olds64 is online now
spyke
September 23rd, 2017 11:01 AM
The Roadmaster
Alero
June 17th, 2015 11:43 AM
Delmont 88 PA
July 24th, 2014 05:30 PM
White Spyder
Brakes/Hydraulic Systems
February 14th, 2013 06:51 PM
carnell71075
November 21st, 2007 03:26 AM
Quick Reply: fuel tank selector valve failure
