Anyone else chase water after wash with compressed air?
Somewhere back along the way I started occasionally chasing water out from under the window trims on my ‘66 big Olds remembering that rust in the rear lower corners had to be repaired on my Starfire coupe 25 years ago.
Just washed the car and chased out a bunch of water which would have evaporated in a day or 2, but I was happy to chase it out and wipe it off.
Do any of the rest of you use your compressor to clean up the inside / outside of your cars? I’m just wondering if I’ve gone too far down the rabbit hole…
Not unhappy, just wondering out loud…
Cheers
cf
Cheers
cf
Not trying to be freaky.
It’s more just that the compressor is sitting there in the garage for various tires (bike & car) and the swap meet blow gun is sitting there for cleaning so it’s sorta “why not?”
Kind of a detail-focused “when you have a hammer, everything is a nail”
Cf
Cf
Cf
Cf
I use both compressed air and an ancient electric leaf blower. Usually the blower because I can sometimes finish the job before the 60 gallon compressor tank pumps up.
Doesn't hurt to aim the blower down the cowl vents either. They're designed to air flush the rocker panels when the car's moving but the more water and detritus you can flush out the less your car will rust.
I'm a mobile car detailer. I always use my compressor to dry out trims for multiple reasons. First of course is rust prevention, but also After a wash and wax, that pesky water droplet could run out from under the trim (especially if the car is moved) and leave a nice streak on your nice, shiny, fresh car! also some dirt and debris wont dislodge with water alone. You would be shocked at what can hide behind a piece of trim!
olds 307 and 403
September 5th, 2022 02:09 PM
