Care and Appearance Washing, waxing, paint care products, etc.
Spic and Span
Old May 7th, 2009, 03:13 AM
Yellowstatue's Avatar
Arrow Spic and Span
Does anyone have any specific product that they use to clean a convertable top in our case it is white; there is a cleaner at Wally World for RV awnings that I am considering using. I have used Javex bleach in the past but am starting to succumb to chemical overload...
Yellowstatue is offline
Old May 7th, 2009, 11:05 AM
Official Tire Kicker
Willidog's Avatar
I don't have a convertable top but I use "greased lightning" to clean things like that. Works pretty good in getting down to the grain but is not too harsh.
Willidog is offline
Old May 8th, 2009, 03:08 AM
Thumbs up Rub-a-dub
Thanks, if I can find that stuff I will give it a try and report back...
Old May 8th, 2009, 03:56 AM
Registered
Bluevista's Avatar
Be careful, anything caustic can eat away the threads and dry out or damage the material or fabric.
I've done mine once in 15 years, the one time I washed the car, hate getting it wet for no good reason.
I used this stuff, black top so not sure how it would do on white but they say it gets out the stains and stuff.
http://www.properautocare.com/ragclean.html
Bluevista is offline
Old May 9th, 2009, 02:57 AM
Unhappy Stubborn stains
We've tried that Ragg Topp stuff and it didn't do what I thought it should... that is when I scrub and scrub and rinse and wipe dry it should be clean but alas it is still dirty and grey ...I used Javex on a convert that I had bought that sat outside for a few years and the white top was almost black...the bleach made it sparkling white...but I don't want to use bleach again for those detrimental reasons...I couldn't find any Greased Lightning so I went to Wally World and bought Full Timer's Choice, RV awning cleaner and tried it on my spare roof that I bought from a wreckers over ten years ago...worked well on the test spot, but on my daughters roof it did not take out the dark rub stains that happens when the top is folded down so we are still looking...
Old May 9th, 2009, 08:51 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I used Raggtop on a cloth top and it worked very well. I used the treatment to seal it with and it was very good. It ain't cheap. One thing I used years ago was Wesley's whitewall tire cleaner. I don't think it hurt the paint. Try with caution. It is available at any parts store and it is cheap.
redoldsman is offline
Old May 9th, 2009, 09:31 AM
Just A BaBy {:
easytobedead's Avatar
kirby {:
easytobedead is offline
Old June 24th, 2009, 09:29 PM
squirtacious's Avatar
If it's vinyl and not cloth I would do it the same way I used to clean my '70 Toro GT's pearl white interior. Spray it down with wesleys bleach white then hit it with a hot soapy mit and hose it off.
squirtacious is offline
Old June 25th, 2009, 05:39 AM
Wesley's Bleach White would surely work well. Like others said though, it might damage the convertible top. Have you tried Simple Green? It is a great cleaner and isn't toxic.
Olds64 is offline
Old August 15th, 2009, 08:33 AM
gearhead1218's Avatar
Formula 303. Located at Marine suppliers.
Some Auto parts stores carry it too.
gearhead1218 is offline
Old August 15th, 2009, 09:01 AM
"me somebody" site member
aliensatemybuick's Avatar
Yellowstatute, a bit off topic, but I've been meaning to ask this for a while...does your user name derive from a joke about some rich Italian guy who tells his contractor he wants a yellow statue in every room of his house, and when the guy finally is able to comply with this wish, he tells him "nooo, I meana a telphona (y'ellow? s'dat you?).
I have a knack for remembering jokes and where I first heard them, and beleive I read this one in the boy scout magazine "Boy's Life" circa summer 1977.
aliensatemybuick is offline
Old September 13th, 2009, 09:42 PM
Dan Wirth's Avatar
If those stains are ground into the fabric in some way, there may be permanent damage and no matter you do, there may be no resolve.
If this proves out and you feel there is nothing to loose, you may want to use and scrub with a more caustic substance like the Bleach White, then rinse to neutralize right away, dry and apply 303 Protectant (can be purchased at a marine supply store - but it's not cheap). Also age and strength of the conv. top material needs to be considered before hand. Keep trying on a test spot first.
Good luck.
Dan Wirth is offline
Old October 13th, 2009, 05:14 PM
crzyjef's Avatar
Which cleaners are better on the Black tops? I really don't much like the idea of bleaching my black top.
crzyjef is offline
Old October 13th, 2009, 06:03 PM
BobsW32
Bobsw32's Avatar
Formula 303 THE BEST STUFF I EVER USED
Bobsw32 is offline
Old October 13th, 2009, 06:22 PM
You're so close with that spic and span quote. Try liquid tide and hot water. Let it soak in, scrub with a soft brush and rinse. Might have to do 2 cleanings, but this works for most fabrics that need cleaning, including seat belts. Goes without saying that you shouldn't do this in direct sun. With seat belts, it's better if you can take them out and soak them in the hot water/tide for about 1/2 hour, then scrub and rinse really well.
Allan R is offline
Old October 14th, 2009, 05:14 AM
Past Administrator
Oldsguy's Avatar
Or, what about those new oxygenated cleaners that are out now? They may be less harsh on fabric than the bleach based ones....
Oldsguy is offline
Old October 14th, 2009, 05:29 AM
You mean Oxy Clean? That might work well. Afterall, Billy Mays did advertise for them... God rest his soul.
Olds64 is offline
Old October 15th, 2009, 02:37 AM
Cool Moniker
It is about a telephone but not about an Italian...I am trying to remember what the heck the joke actually was...I keep misfiling my notes...
Old October 15th, 2009, 02:43 AM
Thumbs up On topic
We finally got some Wesely's cleaner last August when we went to Woodward Cruise, but we haven't had a chance to try it on the roof yet...I used it on the wide whites on the '57 a few days ago and it worked great but they weren't too dirty now if I can just get the Muskrat to put her top up we can do a test run now that the cooler weather is here...
