1957 Olds oil pressure
Old August 20th, 2005, 01:40 PM
<Roy>
Guest
Posts: n/a
Post
I have an original 371 rebuilt engine including a rebuilt oil pump. My oil pressure appears to be low. What should I expect at idle and in normal operating range?
Old February 26th, 2013, 05:03 PM
Pat McClelland's Avatar
My machinist told me 10 lbs per 1000rpm is OK. So at idle you may drop down. I would worry a little about readings below 20 at low rpm but 40 is pretty normal on the road. When we first built my hopped up J2 I ran a stiffer popoff spring in the pump and had 55 lbs but Jim said we needed a cushion of oil rather than a blast and had me reduce it to stock which is around 40 This engine has run well for 20 years all over the US and some of Canada. Pat
Pat McClelland is offline
72Blazerod
January 1st, 2015 10:04 AM
Vandy
November 5th, 2014 11:02 PM
foreverolds
December 1st, 2012 07:07 PM
Railguy
Tech Editor's Desk
July 25th, 2010 02:36 PM
Quick Reply: 1957 Olds oil pressure
