1967 cutlas holiday coupe 330 4 spd
Old April 17th, 2013, 04:29 PM
tulah007's Avatar
It's a project. Got it as a buy the entire lot or get nothing.
Body is very nice.
Interior is complete.
Lots of trim in very nice condition all removed and in the trunk.
Engine turns.
Floor pans replaced.
Rockers and frame rails are rust free
Not much needed on the body .
Engine is a mystery.
Currently the spark plugs and wires are out of the car.
Evidence of coolant around the plugs.
Intake is inscribed 350 performer.
Holley carb.
All complete engine but I don't know what it would need to be a solid engine.
Has a hurst 4 speed floor shifter but has trans cooler lines hooked up to the radiator so maybe a attempted auto conversion?.
Not sure but the lines have snips in them.
Has Mickey Thompsons tires.
Nice vintage mag wheels.
Rust in the trunk floor.
Great project
Tony
301-806-4706
Asking $3100 or best offer
tulah007 is offline
Old April 17th, 2013, 06:05 PM
Pictures?
oldcutlass is online now
Old April 17th, 2013, 06:20 PM
L69
L69's Avatar
pm sent
L69 is offline
Old April 17th, 2013, 08:26 PM
tulah007's Avatar
Not sure how to post pix...
I would be glad to email or text message pix to anyone interested
tulah007 is offline
Old April 18th, 2013, 09:44 AM
67.442.drop's Avatar
Where are you located?
67.442.drop is offline
Old April 18th, 2013, 02:33 PM
tulah007's Avatar
Kensington md. 10 minutes from Washington DC
tulah007 is offline
Old April 18th, 2013, 02:37 PM
Oldsmaniac's Avatar
Can you send me picts j.blusnavage@att.net
Oldsmaniac is offline
Old April 18th, 2013, 02:48 PM
tulah007's Avatar
I sent a few pics.... The rear bumper is in the trunk as well as all of the trim and moldings... All really nice shape too
tulah007 is offline
Old April 18th, 2013, 03:13 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
Darn, wish I was in the market your only 1 1/2 hours away.
67Olds442X2 is offline
Old April 18th, 2013, 03:36 PM
Oldsmaniac's Avatar
Got em, they came small. I was hoping I could post them for you here. The car appears to be saffron and a plain Cutlass...not a Supreme. This car would be more desireable if it were a factory 4spd car. To post pictures go to advanced reply and click manage attachments and a window will pop up for getting the picts uploaded.
Old April 18th, 2013, 05:47 PM
1962oldsguy's Avatar
Text pics? 541-678-0606
1962oldsguy is offline
Old April 18th, 2013, 05:57 PM
allyolds68's Avatar
allyolds68 is offline
Old April 19th, 2013, 08:28 PM
tulah007's Avatar
here is a few pics
tulah007 is offline
Old April 19th, 2013, 08:31 PM
tulah007's Avatar
tried to add a few pics but it didn't work....anyway I got it to work on the 1 post
tulah007 is offline
Old April 19th, 2013, 08:34 PM
tulah007's Avatar
more pics
tulah007 is offline
Old April 19th, 2013, 08:38 PM
tulah007's Avatar
sorry to flood the board but I really only just figured out how to post pics..
thanks for the help guys
tulah007 is offline
Old April 19th, 2013, 09:03 PM
I don't think that's a 330. I wish you were closer, I'd still buy it.
Old April 20th, 2013, 04:04 AM
Oldsmaniac's Avatar
Can you post a picture of trim tag on firewall? Than may help determine if it is a factory 4spd car.
Old April 20th, 2013, 08:20 AM
tulah007's Avatar
The body tag is pictures in the 1st post.
Last pic on the right
tulah007 is offline
Old April 20th, 2013, 02:01 PM
F-85 4-4-2's Avatar
"2L" is the hole for a floor 3- or 4-speed, yes?
F-85 4-4-2 is offline
Old April 20th, 2013, 04:17 PM
Oldsmaniac's Avatar
I believe so 2L is for the floor shift standard trans. With the paint code V-V the car was originally the dark gray color called Antique Pewter
Old April 20th, 2013, 04:32 PM
hurst68olds's Avatar
2L is 4-speed floor shift manual transmission.
hurst68olds is offline
Old April 20th, 2013, 07:48 PM
Trying to remember member
wmachine's Avatar
Right! That would be a B, not an L if it was a 3-spd manual floor shift.
And that is one rare car! Being a Cutlass Holiday Coupe 4-spd and not a Supreme. Which I think is nice to see. (They are faster then the Supreme.....) There were only about 400 4spds in the whole 3600 ("regular" Cutlass) series. Compare that to the 11,000+ 442s in '67 that had a 4-speed!
Of those 400, about 270 were M20 wide ratios and 130 were M21 close ratios.
Last edited by wmachine; April 21st, 2013 at 08:24 AM. Reason: Corrected some bonehead numbers
wmachine is offline
Old April 20th, 2013, 08:02 PM
Originally Posted by wmachine
Of those 300, about 240 were M20 wide ratios and 130 were M21 close ratios.
check your math ~ 130 + 240 = 370
Old April 20th, 2013, 09:02 PM
Navy P-3 FE (Ret.)
Not trying to steal this thread but what would a "2LR" and a "2R" both from Lansing be? A 4-speed non-console and column shift 2 speed auto?
Old April 20th, 2013, 09:10 PM
Each digit is a specific option
there are 5 sets _,2,3,4,5
SET 2
L = 4-speed manual transmission (M20/M21)
R = rear speaker (U80)
Old April 20th, 2013, 09:23 PM
Without L - "4-speed" or B - "HD 3-speed"
& the lack of a G - "sports console" in set #2 would indicate a column shift car.
I'm not sure what would differentiate between manual 3-speed on the column & a 2-speed Jetaway, but a Turnpike Cruiser or 442 would be a column shift Turbo 400.
Navy P-3 FE (Ret.)
Thanks.
Old April 21st, 2013, 08:23 AM
wmachine's Avatar
What does math have to do with anything?!?
Thanks, Dan, it was worse that bad math, I really had the figures all messed up. Should be 270 + 130 = 400. I'll edit that post to save some confusion. Still some rare air.
wmachine is offline
Old April 27th, 2013, 03:41 PM
tulah007's Avatar
NEW DETAILS.
The trans was swapped at some point.
Currently has a automatic trans mounted to the engine.
It has no clutch pedal, bell crank or anything else clutch related.
The 4 spd hurst shifter is still sitting in the trans hump.
tulah007 is offline
Old May 5th, 2013, 09:41 AM
  #31
tulah007's Avatar
NEW LOWERED price in hopes of a quick sale
$2300 or best offer 301-806-4706
tulah007 is offline
Old May 5th, 2013, 07:45 PM
  #32
I don't think thats a 4 spd shifter. I think that is a hurst automatic shifter someone added.
Old May 5th, 2013, 10:16 PM
  #33
tulah007's Avatar
It's a manual hurst shifter. I'm certain because this thing is parked in front of my shop
tulah007 is offline
Old May 6th, 2013, 06:42 AM
  #34
stan 65 cutlass's Avatar
manual hurst shifters are mounted to the back of the trans, is it flopping around inside the hole? or is it mounted to the floor ?
stan 65 cutlass is offline
Old May 14th, 2013, 08:25 PM
  #35
tulah007's Avatar
its flopping around ....it needs a shifter and all that would be needed to mount it....
I do have a m22 that I would be willing to sell.
Im expecting some old m21's too . also I have a 396 built and 454 .
tulah007 is offline
Old May 16th, 2013, 05:04 PM
  #36
tulah007's Avatar
The engine is from a 1958 super88 371
tulah007 is offline
Old May 16th, 2013, 06:31 PM
  #37
Say what?
Old May 16th, 2013, 07:07 PM
  #38
car guy
gearheads78's Avatar
PWI? posting while intoxicated......
gearheads78 is offline
Old May 16th, 2013, 11:30 PM
  #39
tulah007's Avatar
I have decided to hold off on selling fellas.
I had a looker tell me the engine was from a late 50's
Had it confirmed by a gm specialist.
Thanks for the response.
tulah007 is offline
Old May 16th, 2013, 11:32 PM
  #40
tulah007's Avatar
I would still sell the shell pretty cheap if anyone is interested.
No drivetrain , front seats ,wheel well trim. Or shifter.
$1100
tulah007 is offline
Quick Reply: 1967 cutlas holiday coupe 330 4 spd
