1965 f-85
1965 f-85
Good evening from Ontario Canada. I own & am going to start trying to restore a 1965 2 door hardtop F-85 330 olds. I am having trouble finding a reasonable priced frame to swap out with mine. We may try to patch but it is pretty tender in the usual spots. I have also purchased a 1966 delta 88 4 door that I want the motor out of. The rest I will be parting out should anyone need any parts. On the 330 I’m pretty sure the cam angle is going to be the odd one (I believe 45 degrees). Looking for where to purchase a 45 degree performance cam. It has stock #2 heads. Will probably have bigger valves installed if needed & a slight bit of head work. Would like to keep the stock motor but get what I can out of it or do up the 425 or both.
thanks for any guidance
Devin
Devin
bartmobile
July 12th, 2013 08:57 AM
