Frame swap
Old August 9th, 2009, 07:43 AM
convert_crazy's Avatar
Frame swap
Hey All
As in an earlier post I was looking at swapping a 71 H/T frame to a 70 Convert. (Cutlass) After further inspection I think I'll cut out the frame section I need and put it in the 70. My question is, I'd like to use the front discs brakes off the 71. Outside of the spindles will I need to change A arms and the other front end parts ?????
convert_crazy is offline
Old August 9th, 2009, 08:07 AM
2blu442's Avatar
Here's a link to a post Joe make a while back. I found it helpful, read through it and see if it answers your questions. John
https://classicoldsmobile.com/forums...sk-brakes.html
2blu442 is offline
Old August 9th, 2009, 08:29 AM
Lady72nRob71's Avatar
Just keep in mind that the convertible frames are boxed for strength. The H/T frames are not.
If the part(s) you cut out from your 'vert' are boxed, then you must replace them with boxed sections to keep the structural integrity of the car...
Lady72nRob71 is offline
Old August 9th, 2009, 08:43 AM
Thanks rob Hence my change of mind. The repair is just under the trunk floor starting behind where the frame kicks up.
also john That is a great help
Again this is a great group. This is my first Olds build and you've been a great help.
oldsmobilty
September 27th, 2012 04:26 PM
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
DJMatthews
December 5th, 2006 01:28 PM
Quick Reply: Frame swap
