need a source for '67 cutlass relay rod/drag link/center link
Old May 27th, 2013, 07:26 PM
Just the facts...
BILL DEMMER's Avatar
during the course of yesterday's "time spent with ernie", i found that my steering relay rod is toast. upon removing the steering gear box, for an upgrade to the fe3 box, i found the pitman arm to relay rod joint is terribly loose and rough feeling. gm's "better idea" of not designing a grease fitting into the relay rod joints has proven to be a FAIL. during a preliminary search on the moog website and rockauto.com, i've found they don't make/carry a replacement. i'm just looking for a good replacement, this is not a resto job.
any help for ernie?
tia,
bill
BILL DEMMER is offline
Old May 27th, 2013, 07:46 PM
What are you calling a relay rod? Do you mean tie rod?
oldcutlass is online now
Old May 27th, 2013, 08:07 PM
lemoldsnut's Avatar
Never was one for naming cars but if it works for you great. I have 4 66-67 442 parts cars. I have no idea what you are calling a relay rod? The pitman arm is connected to the center drag link and then to the idler arm and tie rods.
Maybe email me a picture with you pointing to what you are calling the relay rod.
lemoldsnut@aol.com
I probably have what you are looking for.
Larry
lemoldsnut is offline
Old May 27th, 2013, 08:28 PM
Just the facts...
gm calls it a relay rod, i've heard/used the term drag link, and i've heard others call it the center link. that's why i put all 3 in the thread title. it's the rod that connects the pitman arm to the inner tie rods and idler arm. it's in the middle of the steering linkage and it looks like this:
bill
Old May 28th, 2013, 04:49 AM
RonFX's Avatar
centerlink
Hello:
Just went thru the same thing for my 66 Cutlass, I located a source called southwest speed in Fort Smith AR. Contact info is 479 646 6988, part #107-224. It arrived on Friday, waiting for frame from blaster so I can paint and reassemble it all. The total cost was $113.00 w/ shipping. Run to Rund also mentions a company called Kanter. Good Luck
Thanks Ron
RonFX is offline
Old May 28th, 2013, 05:16 AM
66luvr's Avatar
Kanter lists them.
http://www.kanter.com///productdetai...Cat=14&Prc=103
Also
http://www.ebay.com/itm/NEW-STEERING...#ht_1886wt_907
I have no knowledge of these parts, just because I have a 66 I searched to see if I could find one and posted what I found.
66luvr is online now
Old May 28th, 2013, 06:03 AM
Trying to remember member
wmachine's Avatar
Seems "centerlink" is by far the most universal term for it. Don't know the origin of the term, but as you say, GM liked "steering relay rod". Would be awfully hard to find in the parts catalog if you didn't know that, but that's half the fun of looking things up!
I've had excellent results with Kanter for suspension parts. Bought a whole front end kit for the Jetstar 1 and there was not a single issue with it.
wmachine is offline
Old May 28th, 2013, 08:33 AM
This same question came up on the AACA forum a day ago. Kanter, Fusick, and Supercars Unlimited all sell the center link for the 66-67 cars. Kanter was the cheapest at $130.
joe_padavano is offline
Old May 28th, 2013, 09:53 AM
Is the same center link used on all "A" bodies (64-67)? I was going to do mine in the near future. This thread got me looking. From what I read there are 2 different diameters.
Old May 28th, 2013, 01:12 PM
RonFX's Avatar
centerlink
Hello:
The guys at southwest speed asked about the end fittings, if they were 7/16 or 1/2 size then double checked about the 7/16 bar size.
Thanks Ron
RonFX is offline
Old May 28th, 2013, 06:42 PM
Just the facts...
the gm catalog list 2 relay rod/center link/drag link/center drag link sizes. 13/16" and 7/8". first type/second type deal. that seemed to only afflict the '64 and '65 f-85 series. the catalog isn't exactly crystal clear on that. i would be more than happy with a good used one, this aint no resto job.
bill
Old May 29th, 2013, 07:57 AM
bill
Correct. I believe the 66-67 center link is the same as the 64-65 second type.
Old May 29th, 2013, 08:51 AM
BackInTheGame's Avatar
I paid about $60 at Rock Auto, online, for a 1968-version MOOG unit. Shipping was cheap, too. You can't go wrong with Rock Auto for hard parts!
BackInTheGame is offline
Old May 29th, 2013, 09:19 AM
Just the facts...
the '68-72 part is commonly available, '67 and earlier is not nearly as available, and is about double the price.
bill
Old May 29th, 2013, 09:26 AM
And if RockAuto (or NAPA, or Advanced, or any other common source) had a listing for a 1967 center link, which is the topic of this thread, we wouldn't be having this discussion.
Old May 29th, 2013, 09:30 AM
Which brings me back to my unanswered question, are any other "A" body center links interchangeable? And is it just a matter of diameter? Is there a difference between manual or power steering?
Old May 29th, 2013, 09:41 AM
No. The A-body cars did not change linkage from manual to power. All parts except the steering box are the same (for a given year).
Old May 29th, 2013, 09:46 AM
So the center link from all "A" body cars can interchange with one and other for model years 66-67 based on outside diameter?.
Old May 29th, 2013, 10:12 AM
That appears to be true. In fact, I can't see any reason why you can't retrofit the second design center link onto cars with the smaller first design. Other than the diameter of the rod, the two are dimensionally identical. The inner tie rod ends are the same for all 1964-67 A-body cars, as are the idler and pitman arms. That tells me that all the center links must be dimensionally the same as well (again, except for the rod diameter).
Old May 29th, 2013, 10:16 AM
That is what my research found, all the holes seem to be the same size for idler, pitman, and tie rod ends. So what's the difference, are we making a mountain out of a mole hill here. Bill can you do us a favor and note what you find that works for you.
For 1966/67 it lists DS740 (7/8 dia) or DS682 (13/16 dia)
Old May 29th, 2013, 10:48 AM
The only "issue" is that unlike most steering and suspension parts, you can no longer simply walk into your local NAPA and buy a center link for ANY 1964-67 A-body. Yes, there are lots of specialty sources, but none of the usual "inexpensive" sources.
Old May 29th, 2013, 11:28 AM
I agree with you on that point Joe. My point is I've seen them as low as $89.00 for a 66/67 Chevelle at Ecklers, Parts place, SS396, etc...
Old May 29th, 2013, 01:27 PM
Agreed, but here's the one that Summit sells for $98 that's listed for all 64-67 A-body cars:
Here's the one Eckler's sells for $89:
Old May 29th, 2013, 01:44 PM
Don't ya hate pictures, the summit one looks right, huh.
Old May 29th, 2013, 01:51 PM
car guy
gearheads78's Avatar
You can't just change the rod diameter. I ran in to this with my 66. I got the larger rod and the pitman and idler I had would not work. The size of the taper was different. Once I ordered the idler and pitman listed for a 67 it all worked.
gearheads78 is offline
Old May 29th, 2013, 09:46 PM
Just the facts...
just for laughs, ernie has a 13/16" diameter piece from the factory.
bill
Old September 8th, 2013, 05:11 PM
Just the facts...
ok, got back on this...
found a seller on ebay with them. brand new, U.S.A. made, with zerk fittings, shipped to me for under $70. seller's name is 4vette on ebay, he has more. pm me with questions, if needed.
bill
Old June 5th, 2021, 07:47 PM
66-3X2 442's Avatar
Center link? relay rod? drag link? Anybody know what a propeller shaft is? I know this is a very old thread but was brought to light in a discussion on FB.
66-3X2 442 is online now
Old June 5th, 2021, 08:58 PM
Propeller shaft is the correct name for what is commonly called a drive shaft, as in the thing from the transmission to the rear diff.
The "axle shafts" are what are called drive shafts in the industry. There are no axle shafts on the factory floor. My plant doesn't do solid rear axles any more since the truck left, so I don't know what we would call a drum to drum rear axle is called in the shop.
I don't have any knowledge from industry of what the steering link stuff is as we use all rack and pinion stuff.
Koda is offline
Old June 6th, 2021, 05:27 AM
Old June 6th, 2021, 06:26 AM
  #31
danktx's Avatar
I used the following from Amazon,
Proforged 116-10008 E-Coated Performance Steering Rebuild Kit
It gets you everything needed. I've had mine for two years with no problems.
danktx is offline
Old June 6th, 2021, 08:22 AM
  #32
66-3X2 442's Avatar
I knew what it was,just making fun of the different terminology for different parts. If you didn't know the name that GMPD used it was very hard to find in the parts books.
Old June 6th, 2021, 08:30 AM
  #33
My car was the test mule for fit and finish for this kit. Parts have been on my car since 2013 with no issues.
I get steering gear setup for free - ClassicOldsmobile.com
Old June 6th, 2021, 09:19 AM
  #34
Truer words were never spoken
Old June 8th, 2021, 11:45 PM
  #35
mpolds's Avatar
For anyone who may be reading/ following this thread, If you are in need of the 7/8" Center Link / Drag Link / Relay Rod -- which fits all of the 1966 & 1967 s -- and some of the 1964 & 1965 s
(that are NOT the 13/16"ths),
I believe I have the best price on planet Earth for these.... Call me (516 - 485 - 1935) or P M me ---
Craig.....
mpolds is offline
kstern58
December 28th, 2014 10:57 AM
brown7373
October 28th, 2014 08:31 AM
BILL DEMMER
November 21st, 2013 09:38 PM
70Cutlass_408
Suspension & Handling
June 30th, 2012 09:59 PM
leslie
January 26th, 2008 04:06 PM
Quick Reply: need a source for '67 cutlass relay rod/drag link/center link
