Removing upper control arm bushings on a 70 442
Anybody know of a source to get an equivalent tool to the Front upper control arm bushing remover. It was a kent moore J-9502-3. Or how did you remove the bushings and reinstall them. I have a press but am having trouble find a washer that I could cut to insert around the bar.
Thanks,
Ben
Thanks,
Ben
Here's a link to a thread by a member. The 70 should be the same as 72.
https://classicoldsmobile.com/forums...tml#post291066
If you want the real thing , here's one;
http://www.ebay.com/itm/Kent-Moore-J...-/281725073197
The easy (albeit, messy) way is to just burn the rubber out with at torch and dent the remaining shell to loosen it. I use a deep socket to press the new bushings in. A piece of angle iron cut to fit between the legs of the control arm prevent crushing by the press.
I was surprised at how easy it was, following that video. Good thing I do have a 1/2" drill with variable speed. My bushing cases were pretty close to welded in there with rust around the outside edges. Took a bit (I mean a LOT) of persuasion even after denting in the casings.
That is messy and smelly. What about using a 1/2" drill to remove the rubber? I did that with the bushings on the rear control arms and it worked like a charm. I saw this video about how to do it and it inspired me to try that. Works the same for control arm bushings.
https://youtu.be/UPXf1OR9Lnk
bigwillystyle
December 21st, 2009 10:05 AM
