Is there a difference between 1968 cutlass/442 frame
Old September 25th, 2011, 02:24 AM
CutlassLegend's Avatar
Is there a difference in the 1968 cutlass and 442 frame. I checked under my car today and it has the nice rusty set of boxed lower control arms and rusty sway bar but the frame appears to be a standard cutlass frame. I know my 66 cutlass and 442 have to diff frames one is a ao smith and the other pontiac or parrish.
CutlassLegend is offline
Old September 25th, 2011, 03:52 AM
svnt442's Avatar
Originally Posted by CutlassLegend
Is there a difference in the 1968 cutlass and 442 frame?
Short answer...nope.
svnt442 is offline
Old November 13th, 2011, 02:38 PM
X2 with Randy. The boxed control arms and sway bar would also have a set of rear control arm to body braces as well. You can buy those pieces pretty much anywhere now. If you have open rear control arms, you can buy the box in and have them welded in. It probably will cost you way less than buying a new set of boxed ones.
I know it's been a while since you posted this. Were you looking at changing out your frame due to rust? FYI, the frame will also be stamped in several places with the last 6 digits of the VIN. For more info on that: https://classicoldsmobile.com/forums...ped-frame.html
Allan R is offline
timrocket72
October 11th, 2013 08:54 AM
Wildcard
November 29th, 2012 08:52 PM
iuhoops83
April 30th, 2010 11:02 AM
Beob
November 29th, 2009 12:07 PM
1BAD68"S"
Drivetrain/Differentials
January 15th, 2007 07:55 PM
Quick Reply: Is there a difference between 1968 cutlass/442 frame
