upper ball joint install ?
Old September 7th, 2010, 06:30 AM
Getting There
Ranzan's Avatar
okay is it just me or do I have to mount the boot retainter to the bottom side of my upper ball joint? this a moog product checked the #s twice before posting this
there is no way it will seat through the top I already drilled the holes out to 5/16
Ranzan is offline
Old September 7th, 2010, 09:44 AM
Run to Rund's Avatar
I gather you are going to use 5/16 grade 8 bolts instead of the supplied 1/4". Yes the boot has to be installed under the A arm.
Run to Rund is offline
Old September 7th, 2010, 01:07 PM
Getting There
Ranzan's Avatar
Thanks Joe I thought I was going nut`s there for a bit.....instructions say from the top
Yes I am going with a grade 8 bolt
Ranzan is offline
Old September 7th, 2010, 09:17 PM
70Post's Avatar
Confirming what Joe said...the original boot retainers slip through the top but not these Moog pieces.
70Post is offline
willypsilon
Suspension & Handling
24
September 23rd, 2014 10:26 AM
arcee1951
March 15th, 2014 11:03 AM
shovel55
March 3rd, 2013 12:57 AM
defiant1
April 13th, 2010 09:32 AM
f85mark
November 30th, 2009 12:13 PM
Quick Reply: upper ball joint install ?
