Will '76 Cutlas Disc Brakes Interchange With Earlier Years?
Old July 19th, 2009, 04:05 PM
coldwar's Avatar
coldwar is offline
Old July 19th, 2009, 07:50 PM
Originally Posted by coldwar
I tried to search this answer out with search function, and am sure I knew the answer long ago, but have forgotten. I am scrapping a '76 Cutlass with disc brakes, and am wonder if it is worth saving the front brakes for the future. Will the assemblies interchange one for one to earlier years, say '71 to 77? Perhaps just '73 to '77? Kindly advise if you know details - Thanks - CW
Unfortunately, not easily. Starting with the 1973 model year, GM changed the ball joint taper on the spindles. It is possible to retrofit the later ball joints and tie rod ends (this is the same effort required to use the B-body spindles), but then you need the shortened upper arms and by the time you go that far, you might as well just get the B-body spindles with the 12" brakes.
joe_padavano is online now
MudEye
June 16th, 2017 10:39 AM
1950 Model Olds
July 20th, 2011 09:12 AM
1950 Model Olds
Tech Editor's Desk
July 20th, 2011 09:02 AM
tsi20gawd
February 26th, 2011 09:19 AM
manny72supreme
August 12th, 2010 02:42 AM
Quick Reply: Will '76 Cutlas Disc Brakes Interchange With Earlier Years?
