09 Fusion Left Front CV Axle
Old October 8th, 2023, 06:31 PM
Tuffnut's Avatar
So when I changed the front struts on our Fusion I noticed a lot grease on the frame. Closer inspection revealed a damaged inner Cv axle boot.
Drove the car for a few weeks with no issues.
so I ordered a new drivers complete CV axle and installed it.
ever since the install I have noticed slight vibration from the engine / transmission from stop to around 30 mph under acceleration, no vibration was present or noticeable before.
I went under to check the new axle and proved there is up and down movement at the inner cv joint. Is it possible I have a new defective axle?
Not happy about maybe doing the job again.
it doesn’t make any noise when turning.
Tuffnut is offline
Old October 9th, 2023, 10:38 AM
Old(s)GuysRule
67OAI's Avatar
Probably not a balanced axle shaft. I replaced both CV front axles on a 2008 Hyundai Santa Fe with inexpensive axles from Rock Auto and have the same issue as you. These replacement axles are smaller diameter than the original and do not have the balancing pads that the originals have.
67OAI is offline
Old October 9th, 2023, 11:27 AM
Tuffnut's Avatar
Im going to order another one and change it out. Send the other back in the new box.
Frustrating, luckily I did the labor myself.
Tuffnut is offline
Old October 9th, 2023, 11:51 AM
woodie582's Avatar
I had both front shafts replace in a Sorento all wheel drive, non oem parts, I had vibration as you described after install. Had them changed to Kia oem and issue resolved.
woodie582 is online now
therobski
January 1st, 2023 09:02 AM
66-3X2 442
November 12th, 2020 09:29 AM
oldcutlass
July 21st, 2017 05:53 AM
BIGJERR
February 24th, 2013 10:12 AM
cutlassgal
December 8th, 2010 02:59 PM
Quick Reply: 09 Fusion Left Front CV Axle
