Anyone see the newest episode of HotRod Garage?
I normally enjoy Hot Rod Garage, the latest episode kinda pisses me off. Between disregarding the cam break in procedure, followed by continuing to run a damaged engine (damage caused by improper cam break in!) to cutting just about every corner possible, seems they were settling themselves up for failure.
Anyone wanna bet the next time the car is seen on the show it will be for a LS swap?🤮
I hadn't seen the rest of it, but I did find is somewhat humerous when they kept going from one engine to the next.
You're right, normally it's not this bad. I wonder if since the car came from VGG/Derek..they're slapping it together and cutting a few more corners since its not theirs.
I'm also surprised as much as they push Isky-they wouldn't take the time to break the cam in per Isky requirements (at least as an additional plug as well as helping the product look more reliable)
