No more Valvoline VR1 racing oil???
Anyone who uses this oil better get to the parts stores before it’s gone.
A few days ago I was in Autozone buying some wiper blades. I noticed they had the Valvoline VR1 racing oil on the clearance rack. Apparently, they are not going to stock it anymore. I stopped at Orielly and advance auto, same thing. WTF??
I have since wiped out all the auto parts stores of their VR1 20W50 inventory. I have enough for my fleer of vehicles for this summer and part of next summer, after that I guess it’s mail order.
On the plus side, I got the oil for 28 bucks per 5 quart jug. The other stores price matched. I see it’s still available on Amazon at 108 bucks for 15 quarts.
The VR1 is still up on the Valvoline website: https://shop.valvolineglobal.com
I usually buy at this site during the sales they offer throughout the year. I've found the sales here to be even cheaper than at Amazon many times. Despite what I said, always check multiple sources before hitting the buy button.
[QUOTE=matt69olds;1553656]Anyone who uses this oil better get to the parts stores before it’s gone.
[QUOTE]
Matt - If it really does disappear, a great alternative is Mobil 1 full synthetic 15w50 Racing Oil, 1300ppm Zinc and 1200ppm Phosphorus. Available at Walmart for $27.97 for 5qt jug. My car loves the stuff.
https://www.walmart.com/ip/Mobil-1-A...Quart/20713647
[QUOTE]
[QUOTE=Dream67Olds442;1553741][QUOTE=matt69olds;1553656]Anyone who uses this oil better get to the parts stores before it’s gone.
My wife kinda bitched about the substantial oil purchases. Her thinking: why did you buy more than you need? My reply; I don’t need all of it NOW, but I will in the future. And it’s on sale. My counter arguments, why do you have so many shoes???
The engine in my car is a roller cam, so it’s not picky on oil. However, the other cars on the hot rod fleets are are school flat tappet cams. I guess if the racing oil becomes hard to find, the only solution is to upgrade the other engines to roller cams!!
Think she will buy it? 😁
I change it every 10,000 miles only because I feel guilty.
My engines usually outlast the rest of the car.
Have any of you guys tried REV X oil additive? Was thinking about trying it.
https://revxoil.com/shop/high-perfor...oil-treatment/
I have used the ZR1, but recently changed to the Lucas hot rod oil for our Studebaker. It has its original 259 with non hardened valve seats or anything. We still run the road tube on it even.
But this discussion got me thinking about changing the oil in it for the summer. What are your guys thoughts about oil change time interval when you don't even put 1000 miles a year on something?
I guess I mean, is there a need to change the oil just due to age? I have been doing it every spring but with minimum miles is it truly necessary? I probably will anyway, but was just curious...
As long as the oil gets to full temp each time it is ran I would not be to worried about time. I have went 4 to 6 years on an oil change and never hurt a thing. Still changed it in less than 3000 miles. Oil don't go bad from sitting. I supposes some of the additives could separate maybe? Even if it did it would mix up again when ran. Now, if you like to start the car up and not run it long enough to get the oil hot, you may want to get it changed more often. I see people start there cars in the winter and let them run at idle for 5 to 10 minutes in the winter thinking they are doing good but that is the worst thing you could do.
We still get to drive it some in the winters here, and while I can get the filter on rockauto and oil at other online places where Oreilly's always has to order the filter, but cant get the oil. I should just stock up I guess. It needs a filter with a restrictor plate, due to way the oil filter circuit works. We have the window sticker where my wife's grandad bought it. I think the oil filter was an $8 option. You can see it is just a bolt on part that attaches to the drivers head, and then dumps back into the fill tube.
It does. Just a little further down. The filter is also supposed to not have a drain back valve in it. When you shut the engine off you can hear it all gurgle back to the block. I don’t know if 61 was the first year for the oil filter but it was close to it. They just didn’t filter the oil before that I guess. Also this only gets 1/2 maybe of the oil at a time just whatever goes to that head. So it eventually all gets filtered.
Does the oil get water condensation in it if it doesn't warm up?
Gravity may cause the oil filter to drain out every time the engine is shut off. Without seeing how it's plumbed it could also cause a noisy startup as the filter has to prime first.
Similar to the Jeep Pentastar 3.6L oiling filtration system that a lot of people bitch about.
That makes sense. It looks like the filter was added after the engine was designed, and they found a pressurized gallery to tap off of and sent it back a pre-existing return. Simple engineering is rarely pretty, but usually effective. I'm sure it was a filter that just hit *some* of the oil each circuit, eventually getting most of it once in a while, as opposed to full filtering each circuit.
Its not messy to change just give it a few minutes to drain itself back down wrap a paper towel around the bottom and go for it.
For me, its stuff like this that make cars cool.
