1968 Cutlass S Convertible transmission
I have the 2sp automatic. I had the clutches replaced about 2 years ago (I rarely drive the car... Once or twice per month). Had been checking the fluid levels regularly. Car sat in my Midwest garage for about 6+ months. The other day I checked the tranny fluid and it's at the low side of the dipstick line. Is that the normal depletion rate? There are no large amounts of tranny fluid under the car in the garage.
Can I add tranny fluid myself to top it off without having to raise the car up?
Also, is there any particular thing I need to look for with replacement fluid?
I let it warm up for about 5 mins then drove about 1mile to the gas station where I checked it. It was about 90° outside that day. Do you think I gave it enough time to get an accurate fluid level read on it?
Also, as far as fluid level is concerned, replacement fluid will show the level just like original fluid. I'm sure that, performance-wise, you could find a cheap fluid that is bad enough that it will damage your trans over time. I'd stick with well-known brands and stay with fluid types that are recommended for the vehicle.
over the years I have used everything from major brand names such as Valvoline, Mobil, etc to store brands from Wal Mart and auto parts stores.
This is good advice. A friend of mine who is in the business uses the Walmart brand of Dextron/Mercon with great success. I'm sure Walmart's product is manufactured in the same plant as some big name product, and is probably the same formulation. You just have to be aware that there could be off-shore manufacturers that aren't so careful with their quality. Buying the "Podunk" brand at "Odd Ball's Auto Infirmary" is probably not a good idea.
I would warm it up for at least 10 minutes, but it wouldn't make too much difference. You also check the fluid level while in park and with the engine running. Is that how you checked it?
Thank you.
