72 Decode help
Old March 8th, 2024, 04:27 AM
Kirkw810's Avatar
72 Decode help
Good morning all, could use a little help please.
I believe it reads 72 34257 LAN457347 977 36 36 4D A53 any help on decoding is appreciated Thank you
Kirkw810 is offline
Old March 8th, 2024, 05:54 AM
ST 72 = 1972 model year
34257 = Oldsmobile (3) Cutlass Supreme (42) Hardtop Coupe (57)
LAN = Lansing assembly plant
457347 BDY = Fisher Body sequence number
TR 977 = White vinyl bench seat interior with arm rest
36 36 PNT = Radiant Green (36) lower and upper body color (a Supreme HT without a vinyl top!)
4D = built fourth week (D) of April (4) 1972
A53 = this is most likely actually A65, which is the RPO code for the custom sport bench seat with the arm rest.
joe_padavano is offline
Old March 8th, 2024, 06:23 AM
Kirkw810's Avatar
Cool, thank you. It's actually got power bucket seats ww/center console. It's highly optioned with rear defroster, 8 track, power windows, power locks, seat belt buzzer when unplugged. Again, Thank you very much
Kirkw810 is offline
Old March 8th, 2024, 06:41 AM
leftlaneonly's Avatar
pic's
leftlaneonly is offline
Old March 8th, 2024, 07:40 AM
Kirkw810's Avatar
Pics.
Kirkw810 is offline
Old March 8th, 2024, 11:42 AM
70W-32's Avatar
A52 is Bench Seat, and your 977 trim code is white bench seat, so the buckets and console were probably swapped by a previous owner.
70W-32 is offline
Old March 8th, 2024, 12:17 PM
Kirkw810's Avatar
My guess also, thanks to all..
Kirkw810 is offline
Old March 8th, 2024, 01:57 PM
And likely a lot of that other optional equipment.
Fun71 is offline
Old March 8th, 2024, 03:14 PM
Kirkw810's Avatar
Appreciate all the help..
Kirkw810 is offline
Old March 8th, 2024, 03:22 PM
Hang on, I posted too soon. In 1972, Olds used the same trim codes for bench and bucket seat interiors. This is unlike prior years. The actual seat style was stamped on the cowl tag.
That's probably an A51, which designates the bucket seats that were standard equipment on the Supreme Hardtop Coupe. Note that Supremes were not available with the RPO A52 Bench Seat, only with the RPO A65 Custom Sport Bench Seat with the arm rest. The Trim Code would have been 977 either way. Sorry for the misinformation.
Old March 8th, 2024, 03:31 PM
Kirkw810's Avatar
Well that's a +
Kirkw810 is offline
Old March 8th, 2024, 08:30 PM
Oldsdruid
rocketraider's Avatar
Wouldn't a factory console car have had D55 on the data plate, since Fisher had to install the mounting brackets?
rocketraider is offline
Old March 9th, 2024, 05:51 AM
Not necessarily. I've seen a lot of cars that did not have it
Old March 11th, 2024, 05:59 AM
Kirkw810's Avatar
Hmmm..
Found this connected to passenger bucket seat, so it is a bucket seat car.
Kirkw810 is offline
Old March 11th, 2024, 06:03 AM
Nice. Fixed it for you.
Old March 11th, 2024, 06:31 AM
Kirkw810's Avatar
Cool, thnx
Kirkw810 is offline
Randomone
July 1st, 2023 03:27 PM
David Hafley
June 26th, 2022 08:35 AM
1970VistaCruiser
May 27th, 2020 02:12 PM
woodie582
January 13th, 2013 06:48 PM
72cuttycoupe
June 21st, 2012 07:42 AM
Quick Reply: 72 Decode help
