Advice on a non functioning gas gauge...
Old September 21st, 2023, 11:19 AM
Donovan
dondon3210's Avatar
1972 Cutlass Supreme gas gauge suddenly not working. Any advice would be greatly appreciated. Thx!!
dondon3210 is offline
Old September 21st, 2023, 11:35 AM
mpowell's Avatar
Fuel sending unit is stuck or shorted out, or the wiring to it is shorted out. Sometimes the ground wire on the outside of the sending unit comes loose, especially on new chinesium varieties.
mpowell is offline
'70 4-Speed W Machine
tnswt's Avatar
This subject has been covered many times here.
Plug this syntax into your browser as a means to search ClassicOldsmobile.com
"classicoldsmobile.com" gas gauge pegged
Hope this helps!
tnswt is offline
Old September 21st, 2023, 12:14 PM
Donovan
dondon3210's Avatar
It does indeed thanks a ton!
Old September 21st, 2023, 12:15 PM
Donovan
dondon3210's Avatar
Looks like the problem for sure. Going to ensure thats it then off to get a replacement. Thanks for the input!
Old September 21st, 2023, 04:13 PM
bccan's Avatar
https://www.chevelles.com/threads/70...#post-11745069
bccan is offline
Old September 21st, 2023, 04:37 PM
One easy test is unplug the sending unit wire where it passes through the grommet in the trunk (left of the latch) and ground the end that goes towards the front of the car.
If the needle goes to E, it means the gauge and wiring from that connector forward is intact and working properly, and there is an open somewhere from the connector towards the tank sending unit and its ground connection.
On my two cars, it was the ground connection to the sending unit (push on bullet connector).
Fun71 is online now
Old September 21st, 2023, 04:46 PM
Donovan
dondon3210's Avatar
Definitely going to give it a shot tomorrow. Really appreciate the feedback.
Old September 21st, 2023, 05:05 PM
Oh yeah, I think you need to have the key in the RUN position for the above test. Gotta have power to the gauge.
Fun71 is online now
Old September 23rd, 2023, 11:12 AM
Donovan
dondon3210's Avatar
Was on the way to purchase an extension for my rachet so I could drop the tank and miraculously my gage started working again. Dropped a can of seafoam in yesterday, not sure if that helped, but after filling up I noticed it's about 1/8th +1/2 off from showing full. Def fuel sending unit at this point you think?
Old September 23rd, 2023, 11:14 AM
Donovan
dondon3210's Avatar
Old September 23rd, 2023, 04:23 PM
No I don’t think it’s the sending unit.
When mine points at the HOT light I reach behind the license plate and wiggle the sending unit wire, then the gauge works until I hit a bump. It’s a loose connection at the sending unit and I am too lazy to drop the tank to tighten it.
Fun71 is online now
Old September 25th, 2023, 06:25 PM
I think mine physically sticks to the tank ceiling if I leave it full for months.
Koda is offline
W-27
April 20th, 2016 10:01 AM
ignachuck
November 5th, 2015 02:05 PM
1954Bob
November 16th, 2013 06:48 AM
MHENDERSON
August 8th, 2013 03:32 PM
trucker442
July 11th, 2012 06:31 PM
Quick Reply: Advice on a non functioning gas gauge...
