guage cluster
Old May 31st, 2008, 03:32 PM
80v8Cutlass's Avatar
guage cluster
My cluster is f'ed......the speedo and is off ~5mph. I want to switch it out with one that has a tach. anyone know what clusters will fit with little hassle that has tach? I have an 80 cutlass suprem LS.
My fuel guage also isnt working, but im guesing thats an in tank problem.
80v8Cutlass is offline
Old May 31st, 2008, 07:31 PM
Oldsdruid
rocketraider's Avatar
Any 78-80 rallye gage cluster will work unless your car has the C-4 system- engine control computer for the layman, with an electronic carb and distributor. All 3.8 V6 cars had it and some gas 350 engines. But since the 442 was the only 1980 A-body to get 350, you may not have to worry about that.
The tachs can be switched for 6 or 8 cylinder cars. You'll have to change the temp and oil pressure sending units, and I think you'll have to move some wires in the cluster plug to get everything working right.
Most every gage cluster I've seen was floor shift so you might lose your shift indicator.
I found one in the shop a couple days ago that I think I pulled out of a 79, probably 15 years ago. No idea if it still works, but there's not much that can go wrong except sometimes the printed circuits get brittle and break. I'll let it go cheap + shipping. PM if you're interested.
rocketraider is online now
Old May 31st, 2008, 11:02 PM
jd75's Avatar
I recently did the swap to a 442 cluster, and it was pretty easy. Found this link where it shows how to do it. http://tech.oldsgmail.com/ch_eint.php I think it looks alot cleaner without having another 3 gauges mounted somewhere. the sending units for temp and oil were pretty cheap and an easy swap. Good luck with it, think you'll like the results if you do it. Also check the ground on your gas tank, thats why mine was off.
jd75 is offline
miko442
March 22nd, 2015 05:06 PM
Finn5033
April 10th, 2012 09:23 AM
toplessrocket
January 30th, 2009 01:23 AM
chevyman
August 5th, 2008 04:40 AM
HAFROD
March 15th, 2007 12:32 AM
Quick Reply: guage cluster
