I Need Interior Door Handle Help
I think there is a special too you can buy to do this. You can get it at any good parts store. This guy bought one and used it on his 85 https://classicoldsmobile.com/forums...oor-panel.html
Good luck, let us know how it works out for you.
I'm hoping I don't have to remove the door panel...
because there is a smaller panel around the lock and handle. I opened it up and looked but, frankly, I could not figure out how to remove the broken handle.
Hi. I'm pretty sure you will need to remove the door panel, and the handle is riveted on to the door. The handle slips into place, then held securely by one big rivet. I changed one on a nieghbours last summer. (Buick, but same car) Handles are easy to get. PM me, if you need more. Hope this helps. Jim.
MaxDog
September 30th, 2012 09:37 PM
m1369d
September 9th, 2012 05:45 PM
