Maybe someone can help me find the data from my Cutlass
Old November 13th, 2021, 06:20 AM
ElioBatista's Avatar
Maybe someone can help me: I could not find the VIN in regular sites.
It is a 1968, the dashboard has a plate Cutlass Supreme, but I´m not sure it is. It is a 350 engine with a 4 mechanic transmission.
VIN 3422878M117948
Plate shows:
BODY BY FISHER
09B
ST 68-34287 LAN121697 BODY
TR 973 D-D PAINT
ElioBatista is offline
Old November 13th, 2021, 06:31 AM
Welcome. Rather than resurrecting a five year old thread, here's your own.
The VIN decodes as follows:
3 = Oldsmobile division
42 = Cutlass Supreme (you have an extra "2" in there, which is a typo - 1968 VINs were only 13 characters)
87 = Holiday Coupe (2dr HT)
8 = 1968 model year
M = Lansing assembly plant
117948 = sequence number
The cowl tag shows:
09B = built second week (B) of Sept (09) 1967
ST 68 = 1968 model year
34287 = Oldsmobile (3) Cutlass Supreme (42) Holiday Coupe (87)
LAN = Lansing assembly plant
121697 = Fisher Body sequence number
TR 973 = blue bucket seat interior with Supreme upholstery pattern
D-D PAINT = Sapphire Blue Poly lower and upper body color
joe_padavano is offline
Old November 13th, 2021, 06:47 AM
There exists a new improved Data Decoder which you might want to review for yourself. The individual who created the tool most likely keeps track of the number of times it's being used - which is good data.
I tried it for your vehicle and this is what I came up with (below). An image of your actual cowl tag would help, as well. The 1968 model year was (more or less) a transition year for cowl tag information the best I can understand. I have never been able to figure out what 973 refers to. Others will most likely chime in. Good luck.
Vintage Chief is offline
Old November 13th, 2021, 06:48 AM
EDIT: Joe beat me to it, and Joe's information will be far more accurate than the information I provided. Yet, there's an opportunity for you to attempt to try the new decoder tool (if you have a hankering to do so).
Old November 13th, 2021, 06:54 AM
Norm, my experience with these decoder tools is that they are frequently incomplete and are A-body-centric. And a library of factory literature provides the same info with greater accuracy.
Old November 13th, 2021, 06:56 AM
Joe, I agree with you. I wish I had the availability of literature you possess!
Old November 13th, 2021, 07:00 AM
Thank you all
thank you Joe
. I'm brazilian and It was not easy for me to find information.
Old November 13th, 2021, 07:06 AM
Bem vindo ao site. Muitos membros aqui com excelente conhecimento Oldsmobile para ajudá-lo. Boa sorte!
Welcome to the site. Many members here with excellent Oldsmobile knowledge to assist you. Good Luck!
Bienvenido al sitio. Muchos miembros aquí con excelente conocimiento de Oldsmobile para ayudarlo. ¡Buena suerte!
Old November 13th, 2021, 07:55 AM
Originally Posted by ElioBatista
thank you Joe
FYI, those are not the factory fasteners holding that cowl tag to the cowl, so it has been removed and reattached at some point.
'46-98
December 10th, 2018 11:02 AM
bear442
November 21st, 2013 04:19 PM
1969oldsH
September 1st, 2012 10:43 PM
x2248344
August 10th, 2012 04:18 AM
Devon76
May 18th, 2007 06:39 PM
Quick Reply: Maybe someone can help me find the data from my Cutlass
