Need help decoding my cowl tag 66 vert
Old February 17th, 2009, 03:08 PM
NorCalAndy's Avatar
Here it is with the engine number any help would be great.
66-33867 LAN
612
088-C
C-1
WS 2XT
4FC 5Y
and the engine number is # 3944173
Thanks for the help guys
also a rebuild kit for the carb. I should be able to take my carb to O'reilly's or Kragens and give them the number and get a kit right? Are there better rebuild kits out there??? Manufacturer?
NorCalAndy is offline
Old February 18th, 2009, 06:34 AM
Trying to remember member
wmachine's Avatar
66-33867 LAN: '66 Cutlass Convertible built in Lansing
612: is this after that "LAN"? If so, the body sequence. *Very* early build
088-C: interior code, have to look further, think it is black strato bench
C-1: Provincial White paint, black(?) top
W - tinted windshield
S - power trunk
2X - column shift automatic
T - power rear antenna
4F - remote driver door mirror
C - Chrome side window sill molding
5Y - deluxe seat belts
wmachine is offline
Old February 24th, 2009, 04:36 PM
NorCalAndy's Avatar
Sorry the 612 is supposed to be C12 it had a white vinyl top and maroon ish reddish interior. it does have a tilt column and a 2 spd glide also power antenna power top and I think it had a remote mirror but no power trunk. Im still having problems decoding the motor..... Thanks
Old February 24th, 2009, 06:43 PM
wmachine's Avatar
Okay, start with the number on the block behind the water pump on the "shelf" in front of the intake manifold. What is it?
wmachine is offline
bigrockingd
June 1st, 2016 06:00 AM
buzz lightyear
January 14th, 2012 09:30 PM
OldsManNJ
June 9th, 2011 07:50 AM
rallygreen
September 15th, 2009 04:02 PM
DesertToro
January 16th, 2007 07:10 PM
Quick Reply: Need help decoding my cowl tag 66 vert
