Radiator top plate question/fan/clutch
Old June 28th, 2022, 03:11 PM
AK71CutlassS's Avatar
Looking for info on a top plate for a 1971 Olds cutlass S. the black one is what came originally on car. 4 blade fan and no shroud
i want to put a clutch fan on and shroud. The other red one has holes. Is that stock to have the holes in that location..?
It is sorta like they were drilled I can’t really tell. I am putting a 455 in
if not what is the correct top plate for fan shroud
what is the correct fan and what is the correct clutch for 1971
AK71CutlassS is offline
Old June 28th, 2022, 03:21 PM
v8al's Avatar
This is the other top plate for a 71. Note this is for a 4 core (thicker) radiator
4 Core Radiator Top Plate, 1969-72 Cutlass/442
v8al is offline
Old June 28th, 2022, 03:31 PM
Yeah not looking for a 4 core top plate. Using a 3 core rad.
Old June 28th, 2022, 03:45 PM
v8al's Avatar
The 3 core top plate looks almost exactly like the 4 core top plate except at the ends where rubber saddles are installed.
v8al is offline
Old June 28th, 2022, 03:46 PM
4speed455's Avatar
Both top plates you have pictured are for non shroud applications. I have this three core top plate for use with a shroud available below.
https://classicoldsmobile.com/forums...coated-145542/
4speed455 is online now
Old June 28th, 2022, 03:54 PM
v8al's Avatar
Personally I wouldn't spend money on a 3 core top plate. I'd upgrade to the 4 core plate and use the 3 core rubber isolators. Then a future upgrade to a 4 core is less of an issue. You still would need to install the lower 4 core saddles and buy the 4 core rubber isolators.
v8al is offline
Old June 28th, 2022, 04:56 PM
K sounds like my two options are original 3 core top plate or a
4 core plate with 3 core insulators
how about the correct fan and clutch PN’s?
chopolds
April 30th, 2022 04:42 AM
72GoldOlds350
April 25th, 2020 12:59 AM
matt69olds
July 10th, 2019 06:43 PM
rothlane'68
June 27th, 2017 09:46 AM
midrange
April 22nd, 2014 02:02 PM
Quick Reply: Radiator top plate question/fan/clutch
