Throttle cable for 68 cutlass 350 4bbl
Old December 6th, 2012, 11:07 AM
jerseyjoe's Avatar
It appears that an aftermarket throttle cable is not made for the 68. All the ones I see have the larger hole that the grommet goes in for the carb. I even tried using the little retainer that goes on the gas pedal from a 1972 and my throttle cable end slips right through it. Had to put the chewed up one from my original gas pedal in when I switched to the TH350. Please tell me I am wrong and there is one out there....
jerseyjoe is offline
Old July 25th, 2013, 11:31 PM
import extermination's Avatar
i bought one for a g body malibu. worked perfect
import extermination is offline
Old April 6th, 2015, 11:36 PM
W-27's Avatar
Were did you buy it? Will it fit a 68 455 4 bar engine as well?l
W-27 is offline
Old April 7th, 2015, 03:27 AM
Are you looking for one of these?
oldcutlass is offline
Old April 7th, 2015, 08:30 AM
W-27's Avatar
Eric, I honestly don't know what that is (but I would like to know) I am looking for a complete throttle cable to fit a 68 442 w/455 4B carburetor.
W-27 is offline
Old April 7th, 2015, 09:10 AM
Octania's Avatar
I thought 1968 [only] had the stubby 1/4" peg that requires a narrow version of the rubber and plastic pcs pictured above.
Let's see the G-body item!
see the peg on this
http://api.viglink.com/api/click?for...mp%3Bvxp%3Dmtr
Octania is offline
defiant1
February 4th, 2020 08:53 PM
convert69
September 6th, 2011 05:27 PM
cutlass1972s
July 6th, 2010 06:33 PM
70Post
March 1st, 2010 08:19 PM
jensenracing77
July 22nd, 2009 05:06 PM
Quick Reply: Throttle cable for 68 cutlass 350 4bbl
