timing chain cover gasket
Old February 15th, 2012, 09:12 AM
jdiggitydogg's Avatar
got a fel-pro engine gasket set timing cover gasket not even close. should i just use rtv? is there a gasket that would work
jdiggitydogg is offline
Old February 15th, 2012, 09:28 AM
Which engine and which gasket? Never had a problem with FelPro gaskets.
joe_padavano is online now
Old February 15th, 2012, 09:30 AM
Oldsmaniac's Avatar
What do you mean not even close? The cover itself slides on 2 dowel pins. These must be clean so cover goes all the way on. The gasket itself is paper thin and should need no rtv but a little high tack or the like can be used.
Oldsmaniac is offline
Old February 15th, 2012, 11:16 AM
i am an idiot wasnt paying attention put it on cover matched fine. ive never had problem with fel-pro either thanks though
Old February 15th, 2012, 11:21 AM
Redog's Avatar
I clean the surface, put a thin layer of RTV down (spread with my finger) put the gasket on, then spread a thin layer on top of the gasket, then put cover on.
This is the way I've been doing my gaskets, and I haven't had a problem
Redog is offline
navvet
March 14th, 2015 05:45 PM
72OLDS-EH
July 5th, 2010 05:00 PM
dallasite21
June 20th, 2010 05:37 AM
crazy'boutOlds
August 6th, 2009 05:40 AM
sklbndt
April 15th, 2009 04:34 PM
Quick Reply: timing chain cover gasket
